Question about Viking 31 in. VECU105 Electric Cooktop
My Viking VECU105 electric cooktop has one burner which will not regulate the temperature. It can be turned on and off with the control knob, but after that, there is no temperature control. Any ideas on what the problem is and how hard it is to fix? That is, does the cooktop need to be removed from counter or what?
  • 59 Answers
It will need either a dual infinite or infinite switch, If the burner has an inner an outer element then it requires the dual.
Firstly turn power off at breaker.
The unit needs to be removed from the cut out and the cover removed from below the swtichs. the knob taken off and the secureing screws removed, then take note of the layout of the wiring and the poistion of the switch, then swap the wires, reassemble test and then re-install
Posted on Mar 05, 2009
Is there a specific regulator for a Viking D3 cooktop or can I purchase one off the shelf?
If it runs on natural gas it has a lower pressure regulator than one that runs on propane gas. Nat gas is 1.1kpa propane is 2.75kpa
May 03, 2014 | Viking D3 RDGSU2605B 36" Gas Cooktop with...
Removing spark module viking gas cooktop
Usually any control knob will activate all four igniters it's usually a faulty pressure switch rather than the igniter pack module.
Apr 01, 2014 | Viking 37 in. VGSU161 Gas Cooktop
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
Viking gas cooktop vgsu161-6b sparks continuously. There is no gas leaking. I spilled water on the controls and it is only when I turn on the 3rd knob from the top that this happens.
The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry though no permanent damage has been done. Leave it unplugged from the electrical outlet for a day or two until the liquid dries out. You can manually light the burners with matches or a BBQ lighter in the meantime. If you want to try and speed up the drying process you can use a hair dryer.
Oct 20, 2009 | Viking 37 in. VGSU161 Gas Cooktop
When i use one burner the other one makes the electrical pop
That allows you to light that burenr turn the knob to mid range for the gas on both or full on and it should stop. there is one igniter and 4 burners. Each burer controls the igniter when oven calls for gas.
Aug 29, 2009 | Viking Cooktops
Viking 30" gas professional series cooktop sparking problem
And before that Most likely one of the ignition switches (they are under knobs) got shorted possibly due to spilled liquid or a cleaning stuff sprayed on. In that case it should stop sparking after a switch drys. Still no go replace the spark control unit.
Thanks
Kindly rate the answer
Kevin
Jul 06, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Electric ignition
try to remove the control knob then cleaning by using vacium.tnxz
Nov 17, 2008 | Viking 37 in. DGSU160-5B Dual (Electric &...
NOT WORKING BURNER ON MY VIKING 6 BURNER COOKTOP VGSU 36IN
Is the little center post of the removable frame over your burners in the little notch where it is supposed to rest?
Aug 18, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Viking 31 in. VECU105 Electric Cooktop Logo
247 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
