I need jumper settings for samsung hd080hg/j drive
    Brigadier General:
  • 3,614 Answers
Setting the order of the hard disk drive (Master, Slave) Jumper Location There are three cases of the installing jumper(shunt) if the jumper is located in the middle of connectors as above.
They are Lower 32GB, Upper 32GB and With capacity limitation in upper 32GB.
i need jumper settings for samsung hd080hg/j drive - 0847eec.gif
MASTER
eb44i need jumper settings for samsung hd080hg/j drive - 5adb2be.gifass=
SLAVE
Posted on Feb 18, 2009
I need to know the jumper setting for my hard drive to set it to a slave
Here is the jumper settings for Samsung hard drives. Assuming that your hard drive is bigger than 32GB you have to use the "General Pin Setting"
Note that after changing the jumper, it's suggested to partition and format your hard disk drive.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 04, 2011 | Samsung Computers & Internet
How to slave hard drive?
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
Mar 19, 2011 | Samsung (MP0804H) 80 GB Hard Drive
Spinpoint hard drive need so set up jumpers as master drive
These can be a pain to find but I managed to dig through all the other info in Samsungs site and get you a direct link to a page with the jumper settings and diagrams.
http://www.samsung.com/global/business/hdd/support/userguide/Support_Setting.html
this link will demonstrate all the jumper settings you should need. If you have any trouble figuring out which ones to use, drop me a reply on this answer and I can help you sort out any additional questions you have.
Hope this helps FixYa,
Chris
favicon.ico PR: wait... favicon.ico I: wait... favicon.ico L: wait... favicon.ico LD: wait... favicon.ico I: wait... wait... favicon.ico Rank: wait... favicon.ico Traffic: wait... favicon.ico Price: wait... favicon.ico C: wait... close.gif close.gif
Jan 02, 2011 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
How can i make my Samsung sp0802 hard drive become the master instead of the slave... thank you very much
Hi Good day!!! follow this
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
7. Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.")
Don't forget to vote thanks!!!
Nov 02, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
I have a samsung 2.5" sata hdd that I want to make it from a master to slave. I need a pin jumper setting info.
You dont need jumper settings for sata hard drive, the sata ports on *********** board have the configuration, just connect the new hdd to the 2nd sata port.
Mar 24, 2010 | Samsung (MP0804H) 80 GB Hard Drive
My samsung cd-rom sc-148c drive is not working. It is not listed in "My Computer". I have uninstalled and reinstalled it but that does not work.
Is the CD-ROM drive on a separate cable on the second IDE controller on the desktop motherboard? Then the jumper setting can be set to Master or Slave if no other drive is connector to this cable.
If the CD-ROM is also on the first IDE controller and IDE cable as the hard drive then the jumper setting on the CD-ROM must be set to SLAVE because the hard drive would be jumpered as MASTER.
Check the BIOS setting to see if the CD-ROM drive is detected.
If the CD-ROM still does not work after you checked and configured the CD-ROM drive, then is is faulty and needs to be replaced.
Dec 16, 2009 | Samsung SC-148 CD-ROM Drive
Reinstalling the original cd rom that came in the computer. do i need to change the jumper settings. it is a samsung sc-148
That depends upon the IDE cable you are attaching the CD ROM to.
There are two IDE cables attached to the motherboard, on IDE 1 connector/cable will be your boot hard drive (C drive) and this will be jumpered to Master and you can attach the CD ROM drive to this cable and set the jumper on the CD drive as Slave.
On IDE 2 connector/cable if there are no drives attached to this cable then the CD ROM drive can be jumpered as Master or Slave..
If there is another drive on the same IDE 2 cable then look at the jumper on that drive, if it is jumpered to Master then the CD drive needs to be jumpered to Slave. If the existing drive is jumpered as Slave then the CD drive needs to be jumpered as Master.
Both drives on the same IDE cable cannot be jumpered with the same setting.
Nov 30, 2009 | Computers & Internet
Jumper settings for samsung dvd drive
There should be a diagram on the drive indicating the jumper positions. Good luck!
Mar 13, 2009 | Samsung SM 352 CD-RW/DVD-ROM Burner
Jumper pin settings
Hold the samsung SP1203N hard drive in your left hand with the lable facing upwards (then power cable connectors will be on your right hand side and the IDE cable connector will be on your left ahnd side). There are two raws of jumper pins in between the above two connectors
Master - join the first two column of pins on the left with a vertical jumper
Slave - leave all pins free (without jumpers)
Cable Select - join the third column of pins from the left with a vertical jumper
job done !!
Udai De Silva
Oct 16, 2008 | Samsung (SP1203N) 120 GB Hard Drive
Computers & Internet Logo
190 people viewed this question
David Payne
David Payne
