Question about VIA MSI K8M NEO-V K8M800 Chipset 800MHz FSB DDR400 Socket 754 ATX Motherboard with LAN, SATA, RAID, ... (MB75MIK8MNEV)
About operating system
Can i load windows xp without using raid driver
    Sergeant:
  • 219 Answers
That depends on how you want to set up your system. If you want multiple hard-drives to work together as one, yes, you will need to load RAID drivers during startup. If you do not want multiple hard-drives to act as one large hard-drive then no, you will not need to load RAID drivers during startup.
I would not recommend loading RAID drivers if you only have one hard-drive. RAID is for two or more hard-drives in the same computer.
Posted on Feb 18, 2009
I tried to install windows xp on sata hard disk but it couldn't find any hard disk in installation.in bios i can see the hard drisk that it shows RAID hard disk 60gb.my msi model is ms-7113 ver 1.what...
get to BIOs ..locate the hard disk ..and change the setting from the ACHI ..to sata like ide..or compatible ..Or ..use use a usb ..or a floppy ..to enter a raid driver for it ..when you install it ..If you pay attention ..when you run the installation of the xp ..Just after starting to load files ..(soon after press any key to boot from cd ) ..it says to press f 6 for to load 3rd party driver ..press it ..and use some kinda memory device ..that will be see..and load teh driver ..and will work )
Or ..just disable the sata raid ..for the hard disk ..and it will be seen after that when you load the operation system ..If it is a newish model ..it will not be affected ..only old models feel the difference in speed between the modes..
Aug 14, 2011 | Intel Motherboard
Tip
How-to repair Windows XP, How to Perform an In-Place Upgrade
One of the best kept secrets of Windows XP is it's built in repair feature!
In previous versions of Windows, correcting an operating system error, or installing a new motherboard, usually meant formating and reinstalling, resulting in loss of all data. Don't worry; Windows XP repair feature won't delete your data, installed programs, personal information, or settings. It just repairs the operating system!
Why would I want to reinstall Windows XP?
1) Can't start Windows XP in safe mode.
2) You have problems caused by a recently installed system update (Windows Update, hotfix, Windows XP service pack, or Microsoft Internet Explorer update).
3) Your problems can't be solved with system restore, or you can't access system restore.
4) You've installed a new motherboard, or made other major hardware changes and need to reinstall Windows.
Let's get started!
Step 1: Rule out hardware issues. Windows Repair will only fix software problems. Hardware issues can also cause boot problems (i.e. bad hard drive, memory, CPU, or power supply).
Step 2: Backup. It's always a good idea to backup your important data before making changes to Windows XP. Relax, if you follow these instructions your data will be perfectly safe.
Step 3: Boot from your Windows XP CD. Insert the Windows XP CD into your computer's CD-ROM or DVD-ROM drive, and then restart your computer. When the "Press any key to boot from CD" message appears on the screen, press a key to start your computer from the Windows XP CD. Can't boot from your CD? Please see the note at the bottom of this page (Configuring Your Computer to Boot from CD).
Step 4: A blue screen will appear and begin loading Windows XP Setup from the CD.
Note: RAID/SCSI/Unsupported UDMA users:
You will be prompted to "press F6 to install any third party SCSI or RAID drivers". Most users will not have to press F6, but if you are running RAID, SCSI or unsupported UDMA controllers, then you will have to have your controller drivers on a floppy disk. If you are unsure whether you have RAID/SCSI, then simply let the CD load without pressing F6.
When completed loading files, you will be presented with the following "Windows Setup" screen, and your first option. Select "To set up Windows XP now, press ENTER". DO NOT select Recovery Console.
Note: The system repair function will remove any updates you have previously installed that are not included on the CD. Drivers will also be reverted to their original XP versions, as well as some settings (network & performance settings may sometimes be reset to their defaults). It may be necessary to reactivate your Windows XP as well. When finished, you will have to download all of the updates from Microsoft Windows Update, because they are all replaced during repair.
Let's get started!
When presented with the screen below. press the F8 key to continue
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation, or install a fresh copy of Windows XP.
If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
Note: If you install a fresh copy, all data on that partition will be lost!
Your almost finished! Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, and have your CD-KEY ready if needed.
Do you have more than one system, or lost your CD-KEY? Visit the keyfinder page to retrieve your CD-KEY.
Update: Due to the proliferation of the Blaster and Welchia Worm/Virus be aware that a Repair Install will leave your system vulnerable. You can get infected within seconds. Do not go on line until you have enabled XP's firewall first.
Remember to run Windows Update! (install critical updates first)
Many computers are not configured to boot from the CDROM. If you cannot boot from the CDROM, this is probably due to the boot order of your devices being incorrect. You can change this in the BIOS.
You enter the BIOS from the first screen you see when you turn your computer on. To enter your BIOS, most users here will press the DEL key.
Most Dell, Toshiba, Gateway, Sony & HP systems will press F2.
Compaq users will usually have to press F10.
IBM typically uses F1 or F2.
Other brands may have different keys to press to enter setup, F1, F2, Del, Tab and CTRL+S. If possible see the manual for your computer or motherboard. Also, the BIOS will usually display which button to press to "enter setup" during POST (if it flashes by too fast, press the Pause key).
When you enter the BIOS setup, you need to change the boot order. The CDROM should be setup before the Hard Drive. Each BIOS is different, but here is an example:
on Jun 18, 2010 | Computers & Internet
Acer aspire one starts to boot up stops at windows xp screen
Hi there !
I suggest you try to run your computer on safe mode by pressing F8 when booting up. Advance menu options will pop up and choose run on safe mode. When it load the Windows, try to figure out what you installed or you before your computer happens. I suggest that you download also windows registry cleaner to fix some errors in your computer that prevent you to go to windows screen when booting up on normal mode. Run the FULL SCAN and press the fix errors button.
I should somehow help your computer.
Feb 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
Have you got a driver for this product please?
usually hard drives dont need driver to be installed seperately, they ll be automatically detected by the operating system and bios. if not check cables,connections, power supply.... if still not working check with other system..
Sep 18, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Scsi/raid host controller
redux1
its old
hp.com has no driver page. now.
end of life for that and XP for 3 years now.
so....
join the HP.forum
then ask for the correct SATA driver
post your PCI codes.
click CP
click DM
click your bad, SATA chip driver.
below is NIC, example, only
then post them on hp link in my 2nd post;
Mar 19, 2017 | HP Pavilion s7310n (EN996AA) PC Desktop
I can not install windows XP on Toshiba Satellite U300, windows
You must have latest Windows Xp CD .
Latest Motherboard chipset does not recognise hard disk without proper sata raid or sata driver. So you can install sata driver if u have USB floppy drive by downloading latest Sata raid to floppy. At the time of installation you will see a message press f6 to if u need to install raid driver.then press f6 asking for floppy drive and floppy insert press enter to continue.
Jun 27, 2009 | Microsoft Windows XP Professional With...
Valid operating systems fro Power Edge 1800
During the Windows XP setup you will need to provide the RAID driver using a pre-formated floppy disk.
Windows will ask you if you want to provide additional drivers and give you the key combination to use to do that.
Jan 21, 2009 | Dell PowerEdge 1800 Server
I am facing Problem installing Windows XP with Asus P5RD1-VM series mothboard with SATA Hard drive. My harddrive doesn't get detected while installing Windows XP. While going for coping files for...
I would go into the BIOS and make sure your SATA controller is using the AHCI or IDE setting and not RAID, if it is using RAID then it may need to load a special driver to install windows.
This is the most likely cause of your problem, can you also check and make sure the bios is seeing the HDD at all?
Jan 21, 2009 | Microsoft Windows XP Professional With...
Problem with new install xp
First of all, was there a reason that you wanted to reinstall windows? If you were having problems with the operating system and now upon reload the hard disk is not appearing it could mean that the disk or the system board itself is bad.
If you pull the XP disk out and just try to boot your computer up are you able to login and use your computer from the previous/original install of XP?
If so, then perhaps you're using a special hard drive controller that supports RAID. If you have a RAID controller you'll need to load the drivers of that controller on a Floppy disk. During the initial startup of the XP install it will give you the opportunity to click the F6 button on the keyboard to load additional device drivers. You want to click F6 when it prompts you at the bottom of the screen and wait for it to prompt you to put your floppy disk (with the RAID controller drivers) in the floppy drive.
Hope this helps. If you need more help just let me know.
MO
Jul 13, 2008 | HP Compaq Presario v3000z Notebook
Computers & Internet Logo
286 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Abhinandan  Patil
Abhinandan Patil
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
