Question about IBM ThinkPad T30 2366 Notebook
Just got laptop. Turn it on it boots up but the
Just got laptop. Turn it on it boots up but the monitor does not turn on. Tried adjusting monitor brightness but that doesn't work. Plugged monitor into external monitor and works fine. I am a newbie with laptops and it may be something very stupid i'm not doing.
  • Ralph  Walekr
    Ralph Walekr May 11, 2010
    You should be able to toggle the external and internal monitor on your notebook. Look at your keyboard near the top. There are keys that have a picture of a monitor on it. If you press the Fn key along with for example mine uses the Fn F5 key to toggle to a external monitor or the lcd screen on your notebook. Try that first. Need to know what type of laptop it is to further troubleshoot. If you can see the first screen like the maker of the laptop when it turns on then the lcd screen is good.
    I hope this helps.
Compaq Presario CQ60 screen is black
also make sure you're not in presentation mode, my vostro (winxp) would randomly boot to presentation mode and turn off my monitor....
upgraded to win7 and it stopped doing it...
Oct 03, 2012 | Compaq CQ60-215DX Notebook
Hi, I have a Compaq Presario CQ60-212US laptop. When I try to turn it on the computer started but my monitor would not display. I've tried plugging it in to a different monitor and tried booting from a...
sounds like your monitor cable has died. This will mean openng the machine up and is a fiddely job,. If you cant connect to an external dispaly with the connection on the laptop....then that is your problem
Jan 05, 2010 | Compaq Presario CQ60-212US Notebook
My asus laptop will turn on but not boot up, the screen just stays black but the green lights come on what do i do?
Have you tried connecting the laptop to an external monitor and starting the computer up?
Nov 25, 2009 | ASUS F3T-AP042C Notebook
My srceen goes Blank
first try booting the laptop and pressing the Fn key with the numerical ( numbered key ) that has a picture of 2 screens on it. This is for booting to an external monitor. you could also try adding an external ( pc monitor ) this will eliminate any motherboard Faults.
Secondly, the graphics chip driver may be corrupt or not installed correctly. if you have a restore cd, you could try booting the laptop, with the cd in the drive.
you can then try, to see if the settings in the bios are all correct, by booting/starting the laptop and pressing esc or F2 or delete immediately as the laptop starts. ** Be-Careful** what you adjust.
My suggestion is to look for. ** default settings tab** or load setup defaults.
these are the obvious things to try, before assuming that you have a faulty graphics chip or motherboard fault.
Mike @ compurepair.
Jun 12, 2009 | Acer Computers & Internet
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
I want to use my laptop as a monitor for my desktop
Check VGA cord connection, possibly try another, shorter VGA cord, plugging in cords BEFORE booting up computer, with monitor power on also. No signal is just computer telling you that it is not connecting.
You may have to go into Setup when computer boots up and turn on or select external monitor as some laptops may require this. Good Luck!
This is a great place for solutions that will save you lots of $$$$. I love it and it is my first contact with FixYA! jaballou
Nov 15, 2008 | CMB T43 750 Notebook
Monitor is on when computer boots up , then turns off
You can email rhartze@key-services.com and provide your telephone number... he will call you to assist.
Dec 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
'Input Format Not Supported' (please help me!)
OK try booting up in "Safe Mode" Press F8 just after Turn on, when and if ya boot into safe mode then adjust your Video settings to say 1024x768x32bit and then reboot, if all good then when you are at the desktop, then adjust the settings to whatever you require... maybe 1280x1024x32bit.. Ya all good. If this doesn't work.. try the Monitor on another PC.. see if it works... if it does.. then maybe ya Video card is going/gone "Toes up" if not, then ya got a fault in your monitor, usually some sort of Power Supply problem or the like.
Jul 23, 2007 | Acer AL1916B 19" LCD Monitor
IBM ThinkPad T30 2366 Notebook Logo
63 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
