Question about MSI K8N Neo4/SLI Motherboard
1long 2 short beeps, No POST/Visual display
Computer worked up until yesterday. upon powering up it gives me 1 long beep then 2 short beeps. and does not POST whats causing it. I have the K8N Neo4 SLI Platinum board with an AMD 2400+ (2.0Ghz) and compatible ram from OCZ DDR400, I'd check the manual but its long been lost.
  • 5 more comments
  • 61r4ff3 Feb 18, 2009
    Id have to check what the model is when i get home. tho if it helps I've located it on MSI's site. link provided below
    http://www.msicomputer.com/product/p_spe...
    well this past weekend I've received the 1L 2S beep when tested with No ram, then with only 1 ram stick in and then back to the normal setup of 2 sticks in (and in different slot. green vs purple). Ive tried a brand new Video card (PNY) aswell as powering it on with no ram and no video card installed and made no progress. I know it helps to have exact info for model # and so on but going on past experience do you think that if i manage to find an identical MSI board and swap over the CPU/ RAM/Video would I get further. or might the issue lye with one of those individual pieces. just trying to think of the best way not to loose my data. i have no problem with buying another board but its the data that i'm more concerned with
    when you say "... CMOS reset and if it doesn't work have it replaced" are you talking about the small (lithlium Ion) battery that sits on the mobo itself. usually on the right bottom side of the board? I'll give it all a shot see what happens. thanks for the help. i'll let you know how it goes
  • Peter Steiert
    Peter Steiert May 11, 2010
    Unfortunately I mean the motherboard. If the CMOS reset doesn't work either the BIOS ROM chip is broken and needs to be replaced or the damage is more extensive than we think.
    Just another thought, have you tried a different power-supply? There's always the possibility the old one blew (which means it could have taken some components with it).
  • Peter Steiert
    Well, as suggested you can attempt a CMOS reset. You won't lose any data as it is all stored in your hard-drive. You can test your memory and your video card(s) on other computers just to see if they work, if they all work properly you know the problem lies with the motherboard and not the components. At that time you would attempt another CMOS reset and if it doesn't work have it replaced.
    If you don't want the motherboard replaced and instead want to buy a new one, you can find some great choices and prices at this website. Just navigate to Computer Hardware>Motherboards. Just don't forget to ensure that the board fits your case. ;-)
  • Peter Steiert
    It's either the video issue or a RAM issue. I read a topic where someone else was getting the same BIOS beeps when he removed the memory (had no memory in his system). This could mean you have bad memory also. Are there any other sticks in the house you could test this theory on?
  • Peter Steiert
    Could we have your motherboard's model number? The majority of the time details on BIOS beeps can be found on the web. However to make sense of all the knowledge out there we have to narrow down our search with the exact model # of the motherboard.
  • MSI Master
  • 4,806 Answers
Hi there
One Long and Two Short Beeps = Video (Mono/CGA Display Circuitry) issue.
If you are using a PCI Express graphics card remove it and use the on-board VGA/DVI port
If it is the on-board graphics you are using clear the cmos
1long 2 short beeps, No POST/Visual display - d015d7b.jpg<<<<< you will see in the picture a plastic jumper (in this case coloured green), move it to the other position and hit the on/off button, then put it back in its original position and power up the machine again. Hopefully the issue will have been sorted.
Good luck and thanks for using Fixya!!
Posted on Feb 18, 2009
  • Lee Hodgson
    Lee Hodgson Feb 18, 2009
    Your going to need the ram installed to even get a post screen, have you cleaned the contacts and the slots with a clean dry paintbrush.
    the beep code is definitely a video error but could also be memory too.
    Clear the cmos as i described
How to boot dell inspiron one 2020 when it only beeps
the number of beeps will tell you what the problem is the beeps are an error code here are the code list for your computer
Beep Code Description No Beeps No Power, Loose Card, or Short. 1 Short Beep Normal POST, computer is ok. 2 Short Beep POST error, review screen for error code. Continuous Beep No Power, Loose Card, or Short. Repeating Short Beep No Power, Loose Card, or Short. One Long and one Short Beep Motherboard issue. One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. One Long and Three Short Beeps. Video (EGA) Display Circuitry. Three Long Beeps Keyboard or Keyboard card error. One Beep, Blank or Incorrect Display Video Display Circuitry.
May 25, 2014 | Dell Inspiron One 2020 All-in-One Desktop
Tip
Tipical Computer/Laptop Post & Beep Error Codes
Error Code: Faulty Component:
_____________________________________________________________
1 short beep None (Normal Boot)
2 short beeps ( POST error)
Non-stop beep ( Power supply or system board)
1 long beep and 1 short beep ( System board)
1 long beep and 2 short beeps ( Video card)
1 long beep and 3 short beeps ( Memory)
3 long beeps ( Keyboard)
Non-stop short beeps ( Power supply or system board,a key on the
keyboard might also be stuck)
None ( Power supply,system board,or system
case built-in speaker)
______________________________________________________________
Visual POST Error Codes:
Error # Range: Component with Error:
100-199 System Board
200-299 System Memory (RAM)
300-399 Keyboard
600-699 Floppy Drive or Floppy Controller
700-799 Math Co-processor
900-999 Parallel Port (LPT1)
1000-1099 Parallel Port (LPT2)
1100-1199 Serial Port (COM1)
1200-1299 Serial Port (COM2)
on Oct 01, 2010 | Computers & Internet
Er-290 wont stop beeping
Step 1:
The beeps are post during post the very first work is done by the ram, all the memory in the ram is first transferred to the hard disk, and remains 1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
http://www.pchell.com/hardware/beepcodes.shtml
Feb 20, 2013 | Computers & Internet
Lenevo t61 1 long beep and 2 short beeo no display
Standard Original IBM POST Error Codes 1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Nov 09, 2012 | Lenovo ThinkPad T61 6457 Notebook
Any help for beeping acer laptop when opening..thanks
g'day!
i would like to know how many and the kinds of beeps? there are what they call beep codes which indicates what kind of problem the your laptop is experiencing: here are the common ones:
0 beep = no power, loose card, short
1 short beep = normal,POST (Power On Self Test), your computer is ok
2 short beeps = POST error, review screen for error code.
continuous beeps = no power, loose card, short
repeating short beeps = no power, loose card, short
1 long, 1 short beeps = motherboard issue
1 long, 2 short beeps = video issue
1 long, 3 short beeps = video display circuitry
three long beeps = keyboard/keyboard card error
one beep, blank, incorrect display = video display circuitry
aside from the 1 short beeps, you need to take your laptop to a technician to have it looked at.
cheers mate!
jelo a.
Aug 21, 2011 | Computers & Internet
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
Post beeps long short short on power up, no display, beep pattern repeats until power turned off. this is after installing this motherboard. Rams are KVR533D2n4/1G Kingston. Isthere somewhere I can find...
1long and 2 short is a video adapter failure, replace the video card and see if the problem goes away, unfortunately if the beeping continues with other video cards, then there a faul on the mainboard.
1 long and 2 short is very common and well known fault in both desktop and laptop computers.
Feb 06, 2011 | ASUS P4B266 Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
Beeps
Code Description
1 short beep System is OK
1 long, 3 short beeps Display adapter problem (EGA)
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
MSI K8N Neo4/SLI Motherboard Logo
560 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
