Question about GE WSXH208A Front Load Washer
GE Adora WHDVH626FGG Front Load Washer - Baffle Broke Off
GE Adora WHDVH626FGG Front Load Washer one of the plastic baffles broke off from inside the drum. Found the piece online but instructions are not included. Any idea how to replace these?
5 Suggested Answers
THENTHEREWER
  • 131 Answers
SOURCE: two 8182233 plastic baffles broke
This is a common problem on front loaders,Once you get the new baffles they just snap in.They have clips.
Posted on Jan 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet baffle broke off under normal use part 3 818-2233
Please report your dissatisfction to the manufacturer.
Thanks!!
Posted on Sep 30, 2010
  • 202 Answers
SOURCE: ge adora front load clothes washer washer smoke
new pump
Posted on Mar 22, 2011
kevin_getz
  • 1031 Answers
SOURCE: GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
Posted on May 06, 2012
Ge adora WHDVH626FWW makes clunking noises when spinning, bearings seem ok
Could be a broken Hub Spoke, My Kenmore broke at the spokesand bearing e.of drum,
Sears replaced all parts as the were still uder warrenty. Less than 10 years old, would have been over $1,000 cost otherwis.
Sep 30, 2012 | GE Wh12x10309 Heater for Adora Front Load...
I left a screw in my jacket that got washed now the screw is lodged between the steel drum and plastic shell, you can hear it scraping when you spin the drum, how do i get to it and get it out
Try to remove one of the plastic baffles inside the spin basket. They are held in place by one phillips head screw. If you take that screw out you should be able to slide the baffle toward you and remove it. Sometimes, but not always, in manufacturing they move a little catch to keep the baffle from moving; in that case it will be hard to slide it. If you can get one baffle out, you will have a pretty good size opening to look for your screw.
May 20, 2011 | Kenmore 44102 Front Load Washer
Two 8182233 plastic baffles broke
Jan 08, 2010 | Kenmore Elite 45986 Front Load Washer
Inside of the washing machine one of the humps or bars broke off. now I have sharp pcs of metal where the hump was attached sticking out. I cannot attach it because the little metal hooks broke.
did it rust? if the metal of the basket broke off then there is not much to do for it. if it is just part of a clip that goes with the baffle then replace the baffle. I would take the baffle to a parts store to compare, they would be better able to help from this point. replacing the basket is something you would find out of the question by cost/labor. if you have a first source servall or appliance parts depot then they would be best. some service companies sell parts too but they would cost more and would have to endure a sales pitch for service
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet baffle broke off under normal use part 3 818-2233
Thanks!!
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer- coin removal
Hi, The coin is probably inside the baffle that tosses the clothes around. I believe this nodel has a screw that holds the baffle in place. I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 28, 2009 | GE WSXH208A Front Load Washer
Broken baffles
yes they snapp right in place, it also comes with a scrw to secure them after installing, hte screwhole is acess by reomving teh top of the unit, and from there you will see a small black rubber hose leading to the top of the tub assy( from the dispensor area) after pulling that hose out of the hole, you can spinn hte tub by hand untilk you line up the baffle hole... thea prt number for the baffle kit is 8182233
Jan 26, 2009 | Kenmore Elite 45986 Front Load Washer
My affinity washer (front load ATF6000ES) is leaking detergent
are you using he detergent?. if what you see on floor is pure detergent then look at dispenser housing for cracks. remove drawer, open, depress lever in back and pull out, to see inside housing. If the screw or mounting for the loose paddle (baffle) broke and slammed housing in some way then you would also have a hole in the tub. You can easily remove top, 3 screws in back to check this. If tub is broke, buy new machine!
baffles are usually attached with screws from outside basket, requiring removal from tub
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Baffle broke off
Hi, one of our baffles broke recently and I ordered a replacement kit from http://www.appliancepartspros.com/
Here is the link that will take you directly to the page:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Baffle-kit--3-pack-item-number-AP3769371.aspx
Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GE WSXH208A Front Load Washer Logo
247 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
