Question about Compaq Armada M700 Notebook
Bios Issue/Hard Drive Upgrade
Techies,
I am trying to update my hard drive on an M700 PIII 850mhz laptop. I have one MK3017GAP, MK3018GAP, and a ST960822A. When I try these I get a message "Fixed Disk Parameter or Bios Error, System Halted". I currently have a MK6014 drive which works just fine. I have looked into the bios settings and found what I am trying to look for is shadowed. When I try seeting up one of the larger drives with Western Digital's Disk Manager it tells me that I need that my bios needs to be set to Auto Configue. This would make sense of why I would get the message "Fixed Disk Parameter". It seems the bios is set to populate the cylinders, heads, and sectors for the 6GB drive. I need to change this to auto or to the c/h/s to match one of the larger drives. Is there a way to do this? Can I do this with a hex editor? If so, how do I go about doing this in the hex editor? And no it has nothing to do with jumper settings on the drive. I even tried using a DDO to try and trick the bios which did not work. DDO does not support this BIOS. I have the most current Bios Upgrade. I have updated this a few months ago. Your assistance would be great. Look forward to hearing from you.
Sincerely,
M700
  • 67 Answers
I have installed a 60gb hdd into an m700 without even having to stuff with the bios...
Xp sp2 allows you to install larger drives then the bios reccomends.
Posted on Apr 02, 2009
Just replaced my hdd on Compac Presario 2100 but the system is not detecting it.
This model laptop came with a 60Gb hard disk and if you installed a much larger capacity hard disk then the BIOS cannot detect this hard disk.
For the BIOS to detect a large hard disk a BIOS upgrade is required (if there is one available) Check the HP/Compaq WEB site to see if there is a BIOS upgrade.
If not the try a 120Gb or smaller capacity hard drive.
As an alternative -
You can keep the existing hard drive in your laptop and use an external USB hard drive to store your data.
Nov 10, 2012 | HP Compaq Presario 2100 Laptop
On the BIOS set up, it will show HDD (none) but if i return the old one the system will detect it.
This model laptop was installed with a 60Gb hard disk. When you installed a much larger hard disk the BIOS could not detect this hard drive.
Check the HP/Compac WEB site foe a possible BIOS upgrade that can support a large hard drive. Otherwise try a hard drive 120Gb or smaller.
Nov 10, 2012 | Compaq Presario 2190US Notebook
On Armada M700 when I try to install windows XP a note tell me there is a disk controll error, soon it goes away, and when I insert the system diskettes on the 4th disk it will not go dfurther it says...
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:>
Once at the A:> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Oct 16, 2009 | Compaq Armada M700 Notebook
Non-System disk or disk error
This issue is related to a hard drive failure.
Remove any disk (if any) from your floppy or cd drive and try again.
Check in your bios if you can see your hard drive
If not your hard drive must be replaced
Nov 19, 2008 | Compaq Armada M700 Notebook
Bios Settings
I had similar problem few years ago.
On the hard drive manufacturer site you should find utility which will "cheat" your laptop bios and control the hard drive bypassing the bios.
Nov 07, 2008 | Compaq Armada M700 Notebook
Installing a Seagate Dive into an Armada M700
Here at my shop I have run into this exact same problem on several P3 Compaq's and a few Toshiba's. I found that some of these machines, not all, but some, will not accept the 5400RPM drive, but will take the 4200RPM drive just fine. It's just weird because some that do are the exact same model, and I'm not real sure why it won't accept them. I've looked into it and the best that I can surmise is that 5400 is too fast for the reading system in the bios, or it's a power issue. Go with a 4200RPM drive and you shouldn't have any problem. You won't be able to tell any difference in the machine's performance between the two RPM speeds.
Aug 01, 2008 | Compaq Armada M700 Notebook
JVC XV841 Hard Drive Upgrade
Hey, I had to replace the drive in mine, It's not too hard. Remove all the screws from the bottom of the case. Snap out the keyboard there are little snaps at the top of the esc & delete key use a small flat balde screwdriver. Then use a credit card around the edges of the main body to help snap it apart. Remove the top half, remove the silver speaker cover. Take out all of the screws holding the motherboard down. Remove the motherboard, The hard drive is under it. A note the ribbon cables are very very sensitive be careful when messing with them you don't want to tear them it will ruin your day ;-)
Jan 22, 2008 | JVC XV841 Notebook
Unplugged my armada m700
 - Floppy drive
 - CD drive
 - Hard drive
At the A:\> type fdisk <press enter>
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
All users
Oct 28, 2007 | Compaq Armada M700 Notebook
CPU Upgrade Help Compaq M700
You might want to check this out I think it answers the questions you are asking? http://h18000.www1.hp.com/products/quickspecs/10382_na/10382_na.HTML
Sep 30, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
192 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
