Question about Rockford Fosgate Car Audio & Video
I need a repair service
I have rockford fogate power series 2000 watts amp. is there a repair shop in illinoise to get it fix. If not where can i get this fix... the amp power light is on it making weird sound in da amp but no sound thru da speakers..
  • Eric Routt May 11, 2010
    Where at in in IL, I also live in IL, need your city to better direct you to a shop.
5 Suggested Answers
  • 119 Answers
SOURCE: Speaker outputs blown on 4 channel amp
the outputs should be replaced in pairs, there are 2 to 4 pairs, but you sould only need 1 pair replaced. these transistors typically range between 10 to 30 cdn each + labour, look for 1 to 1.5h to replace & test the unit after repair. check your local repair shop for their rates. good luck
Posted on Nov 30, 2006
SOURCE: Rockford Fosgate Amp Repair Guild
I would love to get a copy of that repair guide you made. Could you please
Posted on Sep 02, 2007
zzedly
  • 300 Answers
SOURCE: component speaker not working
The easiest thing to test is to try swapping the connections of the front component speakers at the amp connections. If the problem follows the speakers, the issue is probably with the speakers. I would triple check (again) the speaker wire connections. It's also possible the crossover for the driver side component speakers has an issue (thus why the tweeter worked for a while).
If the problem stays on the drivers side, the issue is probably with that channel on the amp. Triple check the RCA connections for that channel.
It's much easier to test other speakers on an amp channel versus trying to check it with a meter.
If the driver's door is "abused" often, my initial thought is the wiring at the speaker or the wiring in the speaker (to voice coil, within the crossover, etc) is the most likely culprit.
Posted on Apr 10, 2008
  • 631 Answers
SOURCE: Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Nov 02, 2008
I have a 5002 Rockford fosgate amp in need of repair. Where can I send it to get fixed? I have my receipt and early repair papers where it has been fixed by the company. It is 1500 watts. Help!
contact the company and get a list of authorized repair agents close to your location
if there are none and it is out of warranty then find an accredited electronic repair shop and ask around to see if they have experience in your brand of unit
Oct 22, 2015 | Rockford Fosgate Car Audio & Video
I have a Punch 800a2 amp and tommorrow im getting the Polk Audio db1222. so my question is do i need a different amp or should this be sufficiant. 12" 2 Ohm db Series Subwoofer Power Handling: Peak:...
Not sure if you are getting two subs or single?
Anyways, amp is rated at 800 watts and probably under rated so it will push sub. Remember that you don't need to worry about max power, rather focus on RMS power rating.
Jan 13, 2011 | Rockford Fosgate Punch 800a2 Car Audio...
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
I have one 12inch 1000 watt mtx sub what size amp should i buy
Hello taona80,
If the 1,000 watts is RMS, I'd recommend an amp in the 750-1,000 watt RMS range, perhaps like the Alpine MRP-M1000 or Rockford-Fosgate T1000bd. If the 1,000 watts is peak power, the subs continuous (RMS) power handling is much lower, probably 300-400 watts. In that case, I'd recommend the Alpine MRP-M500 or Rockford-Fosgate T500-1bd.
Nov 09, 2009 | Nitro BMW-482 Car Audio Amplifier
2 12 p3d212 2 ohm hooking up to a rockford fosgate p325 .1 mono amplifier can it work? and how?
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
Aug 26, 2009 | Rockford Fosgate Car Audio & Video
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Same exact problem
Hello phatjay_31,
It's likely that the sub has been damaged by too much power. The Type R's in both 10" and 12" versions can only handle up to 500 watts RMS. The 15" version can handle up to 750 watts. The Rockford-Fosgate T3000bd1 amp puts out 3000 watts RMS into a 1 ohm load.
I'd check the voice coils. They are probably melted.
Hope this helps.
Jul 19, 2009 | Alpine SWR-1222D 12" Type-R Series...
How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Dec 03, 2008 | Rockford Fosgate 25 To LIFE Punch 150...
Where to take my amp for repair
Contact Rockford for factory service.
If you don't want to send it to Rockford, ask the local audio shops who they use for amp repairs. If several use the same repair shop, it's probably a good place to send your amp.
May 25, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
I have a Rockford Fosgate Puch 1000 watt amp "thermal" problem
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up without the thermal LED being lit, the wiring needs to be checked. If it still indicates that it's in thermal protection, it needs to be serviced. A local repair shop will be the quickest. Rockford will email you the schematics.
Apr 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Car Audio & Video Logo
26 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
