Question about SMC Barricade 7004 Router
License key I am trying to connect my laptop to the Internet from my SMC7004VWBR router but to verify the connection I have to type the 25 character Network license key to activate, could you help me, Thank you
    Sergeant:
  • 219 Answers
This is the wireless encryption key. Follow my directions that I posted here to get some instructions on how to locate it and/or change it.
The concept is the same. You have to log in to your router's control panel to locate the Wireless Encryption Key (which you are referencing as a, "License Key"). In this same region you will be able to change any settings on the wireless encryption and even change your password.
Let us know how it turns out and if we can assist you further.
Posted on Feb 18, 2009
I have got username(admin) password)1234) wanting
Please connect the Netgear Router to your Laptop with a Ethernet cable.
In order to connect Netgear Router to your Laptop please follow these steps:
STEP 1 : If you look at back of router there are 4 LAN ports that are together and 1 WAN or Internet port which is alone. Connect the Internet cable ( provided by your Internet Service Provider) to WAN or Internet port of router .
Now take another Ethernet cable and connect one end of the cable to any one of 4 LAN ports and connect the second end to your laptop. Now please turn on the router.
STEP 2: You can see Power, Internet, Wireless and one LAN port light there on the router. Now come to computer and try to open the router login page.
In order to open the router page , you need to open your Internet Explorer and type 192.168.1.1 in the address bar.Now it will ask for router login information .
Username = admin Password = password
If it doesn't work please try to check the IP address of your computer ( In order to check the IP address of computer, Click on START menu , goto RUN and in RUN Window please type cmd. A black window pops up under this please type IPCONFIG and check the ETHERNET adapter IP address.
Now try to open the router page using this IP address.
STEP 3: Now on the router page you can see number of option on the left side. In order to change or secure the router for wireless connection please click on WIRELESS SETTING option under BASIC SETTING.
Under the SSID : type the name for your wireless network ( of your choice) CHANNEL : it should be 11 or 6 . Security : select WPA-PSK and under key please type any password of your choice ( it must be 8 characters atleast)
Please save the setting.
STEP 4: Now unplug the Ethernet cable from your laptop. Under the wireless networks , you can find your wireless network name . Just select it and click connect on. It will ask for security key or network key please type the same password that you have created for wireless setting.
Now it will connect you to your wireless network that is secured now.
Dec 09, 2010 | NetGear WGR614 Wireless Router
My roommates laptop is connecting to the internet, mine won't
Sometimes the key length would change for security purposes. What you have to make sure is that you are entering the correct network key.
Use a connected computer like your roommates laptop or hardwired connect you laptop to the router using an ethernet cable to access the setup page of the router.
In your browser's address bar, type 192.168.1.1. By default, leave the username blank, password is admin.
Go to Wireless -> Wireless security.
You will see the network key. Just copy that and enter it on your laptop.
I hope this helps!
Jul 12, 2010 | Linksys WRT160N Wireless Router
How do i recover a wep key for a cisco router model wrt310n and thanks
WEP keys are created by the user in the setup or in the security setting inside the router.
You will want to enter into the router via the ip 192.168.1.1 for this model
and check the "key renewal" instruction for the WPA pass-phrase.
this is where you do changes for router security. This pass-phrase is usually 63 characters.
Here are some additional instructions:
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP a dresses.
5. Set the laptop up in the router by WPA KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jun 18, 2010 | Linksys Computers & Internet
Cannot detect network connection
Instead of running the CD, try to configure the router manually. First, make sure that you have verified internet connectivity between your PC and your modem. Once verified, connect your modem to the internet port of your router and then your PC to any of the ports (1, 2, 3, or 4) at the back of your router. Turn ON your modem, router and PC.
On your PC go to Start>Run> then type "cmd" and hit the Enter key.
On the black screen type ipconfig/all and hit the Enter key.
Check the IP address of your Local Area Connection.
If it is 192.168.1.xxx, then you are good to go.
Check the connectivity between your PC and the router. On the black screen type ping 192.168.1.1 and hit the Enter key.
If you're getting replies, minimize the window and open a browser.
Type http://192.168.1.1 and hit the Enter key.
Once prompted with a username and password type admin (admin is the default password).
Once you're on the Web interface of the router, enter your internet connection type and then save the settings.
Once done, click on the Status tab and then check the internet IP address.
If there's an internet IP address, try to open a new window and see if you can access the internet.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Can not laptop to connect
Wireless Troubleshooting Checklist 1. Unplug power from Router and Modem for 3 mins. 2. Restart computer. 3. Make sure your wireless device is active: a. Verify that your wireless device is turned on. Some laptops have a physical hardware switch located on the case. Make sure this is in the ‘On’ position. Other laptops use a Function Key combination (e.g. Dell uses Fn+F2, IBM uses Fn+F5)
b. Open Network Connections (from the System Tray or from the Control Panel). Verify that your wireless Connection is Enabled. If not, right-click on your wireless connection and select ‘Enable.’
4. Renew your connection. Changes elsewhere on the network can sometimes knock out your connection. To reconnect quickly, click Start, Run in XP (or press the Windows key in Vista), type ipconfig /renew, and press Enter. 5. Check for interference. Have you installed any new wireless devices (speakers, baby monitors, ect)? If so unplug them. Make sure your wireless network has a unique name (ssid). 5. If other wireless devices can connect to your router and only your computer can't. a. Try deleting your wireless profile. If you are using the built in wireless for windows go to Control Panel> Network Connections right click on Wireless Network Connection and select View Avaliable Networks. On the left hand side under Related Tasks click on "Change the order of preferred networks" select your network name and click remove. Now try reconnecting to it. Be sure to type in the correct security key. b. Disable your software firewall. 6. If you can connect to the router but not the internet. a. Click Start > Run type CMD into the box and click OK to open a command prompt.
At the prompt type netsh winsock reset catalog
This will Reset WINSOCK entries to installation defaults
When the first one is done tyoe this netsh int ip reset reset.log
This will Reset TCP/IP stack to installation defaults
Reboot the machine. b. Change the name of your wireless network (SSID) c. Change the wireless security key and or wireless security type. Some devices are not compatible with the WPA encription. be sure to use a HEX password Hex is 0-9 and A thru F only. The Hex key
must be exactly 10 characters long for WEP64, or 26 characters long
for WEP128. If you're using 5 characters or 13 characters, it's
really ASCII, not HEX. Please don't forget to rate this solution.
Jun 15, 2009 | Blitzz Technology BWA711 Router...
I am connected to network but have limited or no connectivity
Jun 14, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can't connect to the wireless network with an N+ Router
Jun 13, 2009 | Computers & Internet
HP laptop not recognizing Linksys Wireless B Security Key..
The WEP encryption is consist of 10 characters for 64 bit hex, 128 bit hex is 24 characters and WPA is 8 to 63 characters. So it seems that you have a vista computer? The compatible encryption for vista is WPA, sometime using WEP it is not working properly. So I might advise you to access the configuration of your router (192.168.1.1) and change the wireless settings of your router to WPA-Personal.
Mar 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
Sir, i cant acces irles internet conection from my room,becuse i don't know pasword
Try accessing the configuration page of your router by typing 192.168.0.1 on the address bar of your browser and log-in to the dlink.
>Configure your wireless setting on this window.
>Under setup click on wireless setting
>Then click on manual wireless ....setup
>You will have the configuration of your wireless network.
>You may use WEP or WPA for your password on your security
>For WPA with pre shared key or passphrase the minimum character for your password is 8 characters
>For WEP with pre shared key of passphrase the minimum charactere for your password is exactly 10 characters.
>Once you have save your wireless network
>Go to your laptop and connect to your wireless network before
Jan 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
SMC Barricade 7004 Router Logo
108 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
