Question about Apple M2454 Monitor
I have a Apple Cube and with it a M2454 monitor. The supporting leg on the monitor has been snapped off during transport and the metal connector has been left inside the monitor connection part..... can this item be replaced/ repaired cheaply/easy?
  • 40 Answers
Apple has discontinued service parts for this particular display.
You could try, however M2453 displays can be purchase cheaply on ebay so I doubt it would be worth the expense.
Posted on Mar 02, 2009
How can I find the value of an old apple monitor?
Search eBay for sold listings with the same model number.
Aug 15, 2017 | Apple Computers & Internet
Can apple cider vinegar get rid of skin tags
The answer is yes. Apple cider vinegar can help you treat skin tags in a natural way. Because of its acid, it can break down the cells that are excessive. Just simply, you can soak a cotton ball in apple cider vinegar and apply it to the affected areas. YOu should practise this treatment for one month or until your skin condition gets better. How To Get Rid Of Skin Tags Authority Remedies
May 08, 2014 | Computers & Internet
Replace broken stand (acrylic portion)
Try clear epoxy glue. It will come in two tubes that you mix together. You will need to have a way to hold the parts in place until it reaches full strength ~ 24 hrs. Available at Harbor Freight online or HF stores.
Apr 15, 2014 | Apple Cinema Display 23" HD Monitor
I have a G4 Cube and a 15 inch Apple Studio display. I was using it Saturday and everything was fine, I come in to the office this morning and the monitor is black, it won't display any images at...
acex642, Tell me some real useful info about your lcd monitor!!! How long have you owned it? What is the complete model number and most importantly WHAT IS THE DATE OF MANUFACTURE from the rear lable on the unit? Have you been able to connect a "known good" monitor to the CUBE to prove that it is functioning correctly? Will your "bad" monitor do same thing when connected to a "known good" pc? 12fixlouie
Sep 07, 2010 | Apple Studio (Metallic Silver) 15" LCD...
How the hell does the skirt go on this piece of ****?
Put the metal frame on the board - then turn them upside down. The skirt has four slits - where the knobs on the bottom of the board come through - pull the material tautly while snapping on buttons.
Mar 17, 2009 | Kolcraft Light Vibes 18270 Crib
Black Line bottom of LCD Monitor
May be a manufacture defect or the Screen goes wiped out during transportation.
Call to the support for warranty issues immediately.
Sep 26, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Snapping monitor into stand
You slide in the 2 bent legs, then it doesnt snap. there are supposed to be 2 screws that hold it into place on the top portion of the stand. Find the correct screw size and your stand should keep your monitor up.
Aug 29, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Connecting Apple Studio Display 17 ( LCD ) to Apple G4 Cube
Check the connector coming from the monitor and see if any pins are crushed or touching. It may be shorting power going to it.
Mar 02, 2008 | Apple Studio Display 17" LCD Monitor
Studio display m7649 picture will not come up when connected to toshiba laptop
I am not sure how youve manage to connect these 2 items. You did not specify whic Portage you have, but even the most recent only has SXGA video port. The Apple cinema display connector is ADC. APPLE DISPLAY CONNECTOR. No computers on the planet have this port except for apple's. It's basically a modified DVI connector. In order for you to use this monitor with your computer, you would have to purchase a DVI to ADC connector , which is another APPLE only item and selld for $100 new. You would then have to purchase a SXGA to DVI adaptor...It sounds like a costly endeavor, and with a connections your Portage's onboard video card , amynot even support the resolution for this monitor.
Hope this helps.
Oct 17, 2007 | Apple Studio Display 17" LCD Monitor
Bose Cube Speakers separated
I had the same problem with a Bose separated double-cube Acoustimass speaker/array but was able to fix it as follows:
small, thin, flat-head screwdriver
large pliers
1. Disconnect the speaker wires from the cube.
2. Remove the grille from the top speaker cube. It just pops off.
3. Insert a small, thin, flat-head screwdriver around the perimeter of the speaker. You will have to pry lightly to break the glue’s seal.
4. Using a set of pliers (large, plumber-sized) wiggle the speaker until it comes free. You might need to grip it top to bottom and then left to right. The speaker will come free of the case.
5. Remove the white insulation to get a clear view of the dislodged brace/connector.
6. Stack the top and bottom cubes. Make sure that the rubber seal between the cubes is seated properly and that the black and white cables are not pinched.
7. Using the C-clamp, compress the brace/connector until it seats on one side. Loosen the C-clamp and compress the opposite side. The brace/connector should snap into place. Be sure the make sure that you do not pinch the speak wires that are running through the center of the brace/connector.
8. Test the articulation. It should be the same as your other speakers.
9. Replace the white insulation in the back of the speaker case.
10. Press the speaker into the case’s face. If you wish, you can apply your preference of glue to the edge of the speaker prior to pressing it into the case.
11. Snap the grille onto the speaker.
12. Connect the speaker wires to the cube and you are done.
You should be good to go.
Aug 29, 2007 | Bose Lifestyle 12 System
Computers & Internet Logo
156 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
