Question about Denon AVR-4306 Receiver
Can PS3 go to receiver but not to TV if reciever hooks to TV?
Can I run an HDMI from my TV to my high end Denon receiver and then hook up a Playstation 3 to the reciever but NOT to the TV directly?
  • purliss1 Feb 25, 2009
    No, I want audio and video without connecting the PS3 directly to the TV. I want to connect it to the Denon that then connects to the TV. Thanks
  • 119 Answers
Sounds like you just want audio I would just use the optical audio from the PS to the Denon and assign and input and you;ll have PS video and audio on your tv and just audio at the Denon
Posted on Feb 25, 2009
  • Dennis Scroggins Feb 25, 2009
    Ok you need to connect your PS3 to the Denon HDMI or Component connection, this allows the Denon to be the audio/video switcher and HDMI or component out of Denon to the TV
Denon AVR 1609 7.1 Channel Receiver turns on but i get no sound thru the optical to the tv. what could be wrong?
If you have your video equiptment hooked to your reciever input, then, out to TV, This isn't the best way to go. Of course it depends on what you have for input and output on your TV but, the ideal way to hook your system would be to hook all video equiptment to TV, ie:, cable/sat box, DVD player, etc., to TV via, HDMI, Composite, RCA, etc., then run your digital optical out from TV to reciever. You would use the TV's menu to choose what you watch and would only have one input(audio) to reciever. Some recievers are set up to transfer video, but, it uses more cables, creates more connections, and more room for error.
Jun 13, 2011 | Denon Audio Players & Recorders
I have a cable box connected to reciever and was working fine for months, now i get no picture on tv only sound. I use hdmi cable out to tv that also uses my ps3 to tv which is working fine. What...
I don't know what kind of TV you have and what kind of output capabilities you have but, while your receiver will transfer your video signal, it is not the ideal way to hook it up. The port you are using may have to be reset somehow or, may have gone bad. Ideally you want to hook all video componenets directly to TV then, use, digital optical is best, audio out from TV to receiver. If you have more than 1 input in to TV, you can run your PS3 and cable box directly to TV, using the TV's menu to select which you are using, then, run your audio out to receiver.
May 23, 2011 | Denon AVR-887
Speaker interference
you should be able to disconnect the analog audio cables from the cable box and Denon, with the HDMI connected, press the input mode button on the front left of the reciever to select auto and that should fix the issue
Feb 01, 2009 | Denon AVR588 Receiver
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
HDMI on PC but not on Denon AVR 3805 -
For this situation you will have to take audio output from the TV to an input on the Denon
Jan 11, 2009 | Denon AVR-3805 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
No sound when ps3 is hooked up to a denon avr 1609
The 1609 only has video on the HDMI. No audio comes through the HDMI cables. Hook up an optical cable between your ps3 and the receiver and you should be good to go.
Dec 29, 2008 | Denon AVR588 Receiver
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
I have a new Denon 688 7.1 CH reciever. I did a sound test on all speakers and they all worked. I hooked up Satelite rec HDMI and PS3 HDMI to reciever and then an HDMI from reciever to TV. I have Picture...
The Denon 688 does not process sound via HDMI, you have to run a seperate cable to get sound. Choices are analog audio jacks (red and white) or either a toslink (optical) cable or an rca digital audio cable.
Cheers!
Mar 15, 2008 | Audio Players & Recorders
Denon AVR 4306 receiver not connecting up 1080p with playstation 3
HELLO, I DID A LITTLE RESEARCH FOR YOU AND FOUND IN YOUR MANUAL ON PG 103 IT STATES "RES OF 1080P ARE NOT HANDLED"
Jan 21, 2007 | Denon AVR-4306 Receiver
Open Questions:
See all Denon AVR-4306 Receiver Questions
Denon AVR-4306 Receiver Logo
165 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
