Question about Singer CE-100 Futura Computerized Sewing Machine
Futura ce-100 embroidering in the wrong place
I'm trying to embroider text only on the bottom 3" of the hoop area, but the machine keeps going to the top instead! Very frustrating...... Please Help!!! Thank You!!
I decided to simply start from the beginning and start all over. I turned off the machine, detached the embroidery unit and blew into the sensor (where the machine and embroidery unit connect). I'm not sure what the problem was, but it was fine after that! Just goes to show that no matter how frustrating things can be, it pays to just take a moment and start over!!
Posted on Feb 20, 2009
My Singer Futura keeps beeping and stopping every few seconds.
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Feb 06, 2011 | Singer CE-100 Futura Computerized Sewing...
I have a Singer CE-100 and I would like to know why it keeps beeping and stopping?
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
I have the futura ce-100. When embroidering it
This annoys the heck out of me, cause it happens a lot more than it should. There can be some valid reasons as to why it happens, though.
Mar 22, 2010 | Singer CE-100 Futura Computerized Sewing...
My futura ce200 is driving me insane because i have the small hoop selected on the computer but the machine thinks that the large hoop is selected. How do i fix it??
Before attaching small hoop, turn on power switch to
move the carriage to embroidering standby position, and
turn off power switch.
check troubleshooting in manual
user manual link
http://www.futura-support.com/files/CE200-Eng_Fre_Spa040607.pdf
hope this helps and you get it working soon =)
Feb 05, 2010 | Singer CE-200 Quantum Futura Computerized...
Futura ce-200 "parked" in wrong position.
I think you might have damaged the embroidary arm.
Contact these people for some advice.
Gezina sewing machine
(012) 335 0636
Feb 27, 2009 | Singer CE-200 Quantum Futura Computerized...
"START" ON MACHINE FUTURA CE-100
The start switch is the Led indicator buton. You will see it on page 12 of your manual. It is on the right of the needle bottom button.
Good Luck
Please Rate FixYa!
Dec 19, 2008 | Singer CE-100 Futura Computerized Sewing...
Hi, I'm trying to embroider using my Singer Futura CE-100. After it starts to embroider, it will either bunch up bobbin side or the machine will beep, and the computer says to turn it off, remove hoop,...
could be a threading problem. on the top of the machine, where you go under the plate, pull the thread back and forth like you are flossing. you should feel the thread snap around the 2 wheels, then continue threading. hope it helps
Aug 15, 2008 | Singer CE-100 Futura Computerized Sewing...
I recently bought a Singer Futura CE-200. I was using the embroidery function, but had to stop due to threading problems. When I went back to the computer a few days later my computer was shut down. I...
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Jul 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
127 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
