Question about Kenmore 24 in. 16283 Built-in Dishwasher
My dishes are coming out with a thick cloudy film
My problem is that my dishes are coming out with a thick cloudy film after the cycle is finished. I have tried different dish detergents, rinse agents, and dishwasher cleaning products. I even tried the rumored "Tang" powdered drink solution. My dishwasher is clean, but my dishes are not! HELP!
  • 188 Answers
Most dishwasher detergents now have some sort of rinse agent already in them. If this is the case don't add it to your dispenser once it runs out. Too much rinse agent can cause clouding.
Posted on Feb 19, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The problem is hard water. go to www.dishwasherfilter.com because they sell a filter that goes under the sink and filters the water going into your dishwasher. it will fix your problem guaranteed. it is very affordable and works amaing. www.dishwasherfilter.com.
Posted on May 10, 2009
  • 640 Answers
Ok ,,,first just run a pint bleach wash,,now on your next load,,check your water temperture..is the water over 140 degrees...to hott...onthejob
Posted on Feb 18, 2009
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
My GE profile dishwasher is leaving soap residue on the dishes after a wash cycle. Cloudy and a sort of fim on the dishes. Seems to be getting worse. I use the same dish detergent-Cascade and regulary use...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 04, 2011 | GE Dishwashers
Frigidaire dishwasher FDB1500LFCO is not cleaning dishes properly. Glasses have a cloudy apprearance, other dishes are not clean, silveware is a mess. Have hard water so am using LemonShine for hard...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Frigidaire FDB1502RG Built-in Dishwasher
Dishwasher seems to run for a very long time on normal cycle. It leaves a whitish residue on dishes and the glasses appear cloudy. I do use a rinse agent.
heatman101
Nov 21, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Some dishes and silverware ends up with a cloudy film on it.
Usually this is a contanimation issue, check and clean all drain filters, look for particulate matter in the spray ports, Usually you have to take the whole thing apart and clean debris.
Sep 28, 2010 | Dishwashers
Dishwasher leaving a white film on dishes after wash/dry cycle
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
Mar 18, 2010 | Kenmore 16764 Dishwasher
JDB6510 dishes have a cloudy film
check your screen or strainer in the bottom of the unit it is what filters the water to the pump if it has some trash in it or is plugged it will reuse the old water to rinse the dishes
Aug 22, 2009 | Dishwashers
After running a full cycle dishes are covered in detergent residu
www.dishwasherfilter.com has a great product specifically for this problem. it filters the water going into your dishwasher removing the hard minerals that cause this problem. after the first load my dishes looked amazing. it is very affordable and fits right under your sink.
Apr 01, 2009 | Asko D3251HDSS Stainless Steel Built-in...
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Not draining properly, leaving film, debris, & soap, draining through air gap
you wont get clean results if loading a dishwasher up with dirty plates, the food debris will circulate around with the water and keep reistating itself on the plates- as it may not get through the filters. try a powder wash with rinse aid topped up and the most important thing is that the salt bottle is topped up. you may also want to check that the spray arms are not all blocked up with debris.
Jun 03, 2007 | GE 24 in. GSD2120C Built-in Dishwasher
Kenmore 24 in. 16283 Built-in Dishwasher Logo
456 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
