Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ice maker not turned on or hooked to water line
Ice maker still making a clicking sound 3-4 times a day for about 30-40 mins. We do not need the ice machine hooked up. I have the ice machine in the off position and it still makes that noise. The water line is not hooked up. How do I get it to stop making that clicking noise throughout the day?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
It my be not the icemaker check fan or you can remove icemaker
Posted on Apr 06, 2009
My kenmore side by side is not making ice
when was the last time u change your water filter, if water is coming into the ice maker and it don,t make ice that means u have a defective ice maker, if no water comes into the ice maker check the water valve at the back of the refrigerator with an ohm meter for resistance if no resistance is present replace water valve,u should unplug water valve when checking
Jan 16, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The water is leaking from the ice maker . how can I turn it off, or close the tap
U can trace the line back to where it hooks in to water line and un hook it
Dec 19, 2012 | Refrigerators
Ice maker won't fill with water
Well the ice maker itself is what calls for water. It probably is fried. The way it works is the ice maker basically sits in the freezer and waits until the ice mold reaches 28f. When it gets to 28f the ice mold thermostat closes the electrical circuit to the heater and the motor. The motor basically stalls out because the heater hogs all the power. As the ice loosens the motor does not need as much power and manages to move the ice till you hear a CLICK and that is what kills the power to the heater and the resulting surge moves the ice on around at an astounding snail pace not unlike watching grass grow. At near the end the water valve gets energized by a probe rubbing against a copper plate located behind the main drive gear. over time it gets to where the arcing sticks the probe to the plate and instyead of 7 seconds of fill time it fills for 25 or more seconds or just smokes up the puppy and burns the tip of the probe.
Dec 12, 2012 | Kenmore Side by Side Refrigerator
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
Brand new Kenmore refrigerator, ice maker does not work
first off relax and give it time the ice maker need to cool to a certain temp before making any ice, 24 hours is a reccomnded minimum
Jan 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Ice maker not making ice after replacing water line.
Ice makers are a common problem. On many brands there is a reset button behind the plastic cover. However if you physically see Ice clogging your water inlet to the ice maker, this will without a doubt prevent the ice maker from making ice. Use hot water or a steamer to unclog the ice or you can leave the unit unplugged for a few hours to defrost the freezer. You should be able to hear when the ice maker cycles and lets in water. Note: if you're getting plenty of water out of your in door water dispenser, then it's NOT a water supply problem. You may need to check the solenoid that controls water entering the ice maker.
Nov 29, 2008 | Refrigerators
HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Apr 22, 2008 | Refrigerators
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
323 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
