Question about Belling Ovens
Grill element not heatingelement has been checked and is ok
    Problem Solver:
  • 11 Answers
1. remove element, check the voltage should be about 220 volts across the wires.(warning this can KILL YOU have somebody that knows what they are doing check it) remember to turn on at knob when ready and turn off too!
2. if no voltage, check breaker, or check it first, some may have a 110 curcuit for lights and a 220 for elements
3. if voltage is there the element may still be bad, if it was checked with a ohm meter, reading may have been bad, but looked OK.
4. If other elements work I would check switch next with the volt meter not ohm. incoming and out voltage.
Thermostat may have went bad.
5. replace as needed.
Posted on Feb 18, 2009
The grill element gets warm but not hot enough to cook. I think this means the element itself is ok but something else isn't. Any suggestions?
could be a faulty thermostat or a problem switch for the grill
call in a technician for a proper diagnosis
Apr 30, 2016 | Ovens
Grill is inop, but all other parts work e.g cooker, hobs
ovens usually run on 3 phases ensure all 3 fuses or trip are ok.
2. check gill element for any visible breaks or holes the element maybe defective.
this would need an engineer to check and replace.
3. the grill control knob maybe defective also would need an engineer to ensure
electric is getting through the control.
NOTE Electricity is leathal and should be handled by an experienced and qualifed person.
I hope this was helpful
May 03, 2011 | Ovens
Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Feb 11, 2011 | Ovens
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 14, 2011 | Smeg Ovens
My grill doesnt seem to be working,the oven seems to be ok making all the noise and stuff but the grills just not playing ball! nany help would be appreciated!
More than likely the grill element has failed, if the element light comes on, then I would go for the element.
If no light, then probably the grill switch is faulty.
Nov 14, 2010 | Zanussi ZBF360 Electric Single Oven
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Ovens Logo
81 people viewed this question
Top Belling Ovens Experts
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
