Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Cannot get machine to callibrate
I am just setting up my printer and cannot get machine to callibrate - the paper light is on, the on/off button is flashing green/the screen say please wait - it has been 4 hours, I think I have waited long enough
  • 28 Answers
Unplug the power from the back of the printer, wait 15 seconds and then plug it back in for a reset, Rob
Posted on Feb 20, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
When i plug in the printer and turn it on, the green light flashes alternately with a yellow light, displaying the number 2 on the little screen (green, yellow, green yellow...)
Greetings - According to the MP210 manual the error is "the machine is out of paper/paper does not feed."
The remedy according to the manual is "reload the paper correctly and press the Black or Color button."
Hope that does it.
Regards, Mikeywaf
Mar 04, 2011 | Canon PIXMA MP210 InkJet Printer
Hi I have a gk420d zebra thermal label printer and I have been having a problem where the light on the printer continues to flash orange green orange green how do I go about sorting the problem out....
Try to calibrate the label length.
with the feed button pressed switch on the printer.
Keep the button pressed until you have Seven flash of the green led and release the button.
The printer will do a manul callibration.
After that when you press the feed button it should feed one label
Dec 17, 2010 | Zebra 2844-Z Thermal Label Printer
The labels are printing off out of allignment on my (zebra LP2844), the bottom of the address is carrying down onto the next label ?
Your physical labels size is not matching the label size set in your printer driver and also you need to carry out a callibration.
Hold down the front button
Turn on the printer
After the light flashes 2-3 times red release the button
The printer will now callibrate
After callibration press the button once
Dec 16, 2009 | Zebra LP 2844 Thermal Printer
I HAVE A RICOH 1515MF ANS THE PRINTER LIGHT TURN TO red and there is a flashing green light 2 inches below it
Press the printer button, it will tell you on the screen what the problem is. Generally it is because your computer is telling the printer that it wants to print on a size paper that you don't have loaded in the machine.
Nov 16, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
TLP 2844-z Flashing Red Light When I Try To Print
When the light flashes red, press the green button once. What happens then?
Oct 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
