Question about Xerox Phaser 6250N Printer
Printing very light and lines down the side of the paper
Have you changed image unit ? if not that may be a good start. You can try to clean contacts it all depends on the look of the lines.
Posted on Apr 17, 2009
I have a lexmark x6570 printer it will not print on both sides of the paper anymore it use to print on one side then pull the paper back in as use the other side
Please follow steps below on how to print 2-sided on your printer:
Printing on both sides of the paper (duplexing) automatically:
  1. Press printmastert_76.jpg.
  2. With a document open, click File > Print.
  3. Click Properties, Preferences, Options, or Setup.
  4. Click the Print Layout tab
  5. From the Duplexing area, select Use Printer Settings from the drop-down box.
  6. Make sure the printmastert_77.jpg light is on.
  7. Click OK to close any printer software dialogs that are open.
Printing on both sides of the paper (duplexing) manually:
  1. With a document open, click File > Print.
  2. Click Properties, Preferences, Options or Setup.
  3. Click the Print Layout tab.
  4. From the Duplexing area, select Manual from the drop-down box.
  5. Select the Print manual duplex instructions check box.
  6. Press Start.
  7. The printer prints the odd-numbered pages and the instruction sheet, which describes how to flip and reload the paper.
  8. Following the instruction sheet, flip and reload the paper with the printed side facing away from you.
  9. The printer then prints the even-numbered pages on the reverse sides of the odd-numbered pages, completing the two-sided sheets.
Note:
  • printmastert_78.jpg button is not functional with a Macintosh operating system. You can print two-sided documents with a Macintosh operating system by using the settings in the Two-Sided menu of the Print dialog.
  • Automatic two-sided printing (duplexing) works only with plain paper in letter and A4 sizes. If you want to print two-sided documents on another size or type of paper, use the manual duplexing method.
  • To return to single-sided printing, make sure the printmastert_79.jpg light is not on.
Aug 31, 2011 | Lexmark X6570 InkJet Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Panasonic DP8020E Black and White Copier error message 13
panasonic dp8020e copier / the wrench light and another light to the far left side that looks like lined paper are on and cannot print. I had some instruction but did not get them all. They start with;
press and hold the function key
original size and the #3 key
f1 self test 9 hit down arrow
f9 hit down arrow
hit down arrow to 06 hit set button r/paper code
func reset
set yes to see if paper prints, can you correct and complete the instructions for me. Thanks MShea
Jul 04, 2010 | Panasonic Office Equipment & Supplies
Lines in printing
...maybe its time to replace fuser fixing film!?
Nov 10, 2009 | HP LaserJet 1020 Printer
I have an okidata 320t that is loading wierd. The alarm light is on when I put a paper in the top feed the alarm light goes out, but the paper doesn't load untill you push the SEL button and then when you...
1st try the easy stuff is the leaver set as paper feed or tractor feed if that is set correctly then you most likley have a gear problem and they need to be replaced.
open up the printer replace all the gears on the right side and the large gear on the left
they cost about 8 euros each and if it does not park correctly just clean out the bits of paper stuck under the paper load leaver the leaver is small black and bobs up and down if it does not bob up and down it means that there is a bit of paper stopping it. (to do this you have to remove the large black roller that feeds the paper)
thanks Hackeridis
Apr 16, 2009 | Okidata 320 Turbo Printer (Remanufactured)
Lines on print
check your paper guide and then run through it's maintenance test. then run another test paper.
Jan 05, 2009 | Kodak Easyshare Printer G600 Thermo...
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Blue smudging down left side of the paper and paper turning greyish color
check the fixing unit if the adjustment for envelop is activated or not the same. set to normal.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
Xerox Phaser 6250N Printer Logo
65 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
