Question about SanDisk Sansa e260 MP3 Player
I have a sansa e260, 4gb capacity, that has a spot for micro sd mini chips. I recently puchased a 4gb mini sd ghip that is 4 gb and loaded it up with about 3.89 gb of music and the sansa will not detect the chip or its contents
    Problem Solver:
  • 18 Answers
The Sansa, in common with many devices which have been around for a while, will only recognize standard micro SD up to 2 GB, not the SDHC (High Capacity) variety.
Posted on Feb 19, 2009
Why is there no manual with my sansa fuze
For the Sansa Fuze there's a manual available in pdf format on the Sandisk support site:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Save this file to a location on your computer for later use.
When you explore "My Computer" the micro SD card with x GB memory, should be available as an extra external drive.
This drive will show up as an extra drive letter with a total capacity of x GB .
Apr 24, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Installing Micro SD card to Sansa e260R
The Sansa e260 Rhapsody (e200R series) supports:
1. micro SD cards ( not the HC type )
2. micro SD cards up to 2 GB of memory capacity
See next site:
http://kb.sandisk.com/app/answers/detail/a_id/200/related/1
Jan 10, 2010 | SanDisk 4GB microSD High Capacity Memory...
Is there a spot for a micro chip on the sansa e250
Yes it does have a slot for microSD card on the right side
Aug 04, 2009 | SanDisk Sansa e250 MP3 Player
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Jun 29, 2009 | SanDisk Sansa e260 MP3 Player
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Jun 05, 2009 | SanDisk Sansa c240 MP3 Player
Sandisk Sansa C250 won't recognize 8Gig micro chip
Your model doesn't natively support SD cards over 4GB, however I hear you can install something called "Rockbox," it's a free third party firmware that allows you to dual boot between "Rockbox" and the Sansa firmware. "Rockbox" adds the support you need for SD cards with a capacity of 4GB or more. I've never used this firmware, but it does sound promising.
Download it here
Sorry I couldn't be more help.
Jun 03, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Adding a 8GB MICRO SD card to the Sansa e260
I read somewhere that a 4 GB Micro SD card is the largest you can put in the SanDisk Sansa E260 expansion slot. It's maximum capacity is 8 GB, with internal + external memory put together. This is from what I've read. Hope this helps.
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
Mp3 Player not reading SD 1GB Card
The Sansa is unfortunatley one huge mess up the programming has failed its working on a database with only 4 levels but for grphics and songs you need at least 7 lhopefully you can return it and get another if not you can try putting another type of chip hopefully that will work
Apr 11, 2008 | SanDisk Sansa e260 MP3 Player
Memory stick not identified.
The memory stick probably is not the right type. The Sansa only takes SD Micro chips. However, IIRC Micro only goes up to 2GB. So, if you have a 4GB chip is must be a SD HC (High Capacity). Unfortunately, these do not work in the Sansa.
Feb 28, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
247 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
