Question about Archos Internet Media Tablet MP3 Player
I just put the gps demo firmware on my archos 605 wifi but everytime it gets onto the menu it shuts down 2 seconds later and at the start it says something like shutting down a unit???
  • 61 Answers
You need a gps dock goes for the unit Gps dock has TMC and Satellite antenna without it it wont work of course that it is the reason it shuts off. not recognizing the antenna
Posted on Feb 18, 2009
Cant watch videos on web on archos 605 wifi
You should be on firmware version 2.1.04 (WMDRMPD:10.1) If connected to your computeer or on WiFi then :- Main Screen Menu Settings Firmware + Plugins and click on.... Online Firmware Update This version of the firmware does allow some videos. Unfortunately if the videos come up with blank screen with a red F9 in the middle this signifies a version of FlashPlayer not yet supported. We just have to wait and see if Archos are still going to support the 605 with more firmware updates or if their hands fare too ull with the new Archos 5 Android.
Apr 02, 2010 | Archos 605 WiFi Digital Media Player
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 20, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 has got recovery code 102 and i cant get it to conect to my pc to fix it can u halp
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
Mar 19, 2009 | Archos 605 WiFi Digital Media Player
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jan 21, 2009 | Archos 605 WiFi Digital Media Player
Map code
I had the same problem. "Invalid Map Code", etc. I went to archos.com/gps_install, and followed the directions. I had to update my 605 wifi firmware. Once I did that, I entered my map code and map version (found the version on a .txt file on the dvd, forget which one), and followed the directions from there. Seems to be working so far, although I haven't actually taken it on the road yet (can't seem to get a GPS signal in my garage).
I'll post a follow-up once I know it's working.
Oct 22, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Problem: Archos 605 Recovery code 108
This is generally due to failed firmware updates, etc....here is something to try that has worked for some others:
1. connect the archos to the PC
2. click on repair
3. click on done and wait for a few seconds and you will see the archos as a drive in your windows (be patiant it takes some time)
4. once you see the drive, open it and make sure the System folder is empty, if not delete the file that exists there.
5. download firmware from archos website and put the firmware update file directly on the root of the archos drive
6. click repair again on the archos and done.
I've been told this does not always work on the first attempt, so give it a couple of tries if the first attempt fails.
Oct 16, 2008 | Archos 605 WiFi Digital Media Player
ARCHOS 605 WIFI FIRMWARE DISABLED
hitesh_rao - the reset button is at the bottom by the USB and docking ports. Tiny hole, need a pin or paper clip. Once pressed, just switch it back on.
This may be a stupid question, but when trying to configure the TV IR controller function and entering the relevant codes for my TV's, it asks 'did the TV switch off = Yes/No?'
None of my TV's switch off and then I cannot go any further with the config. Is this right? I have logged this with Archos FOUR times now, and they just respond with 'the controller does not control your TV'. I am fully aware that it is not a TV controller, but then why does it want to switch off my TV during the config? I just want them to answer that question.
Somebody please help!
May 22, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 parental code
i got the same problem, somebody help us please?
Mar 29, 2008 | Archos 605 WiFi Digital Media Player
Think i have broken my archos 605
Go to the archos website on your PC and download the latest firmware. Once you have the firmware downloaded to your desktop, connect your archos to the PC with your usb cable.
The computer should recognise the archos as an external drive.
Open the archos drive on your desktop and drag the new firmware into the window. The computer will copy the new firmware onto the Archos drive.
DO a safe disconnect from your pc and restart your archos. The new frimware should start to load itself on your Archos when it powers up. You will need to reconnect the usb cable for the downlaod to start running. Once it is finished it will restart itself again. You will probably need to recalibrate your touch screen interface as well. You need to use the buttons on the side of the unit to scroll through the menu to get to the "settings" screen, and then the "display" screen. Choose "calibrate touchscreen" and follow the instructions.
I hope this helped.
Mar 23, 2008 | Archos 605 WiFi Digital Media Player
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Feb 23, 2008 | Archos 605 WiFi Digital Media Player
Archos Internet Media Tablet MP3 Player Logo
246 people viewed this question
Top Archos Audio Players & Recorders Experts
Justin
Justin
George Hoggarth
Level 1 Expert
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
