Question about Kenmore HE2 Plus Front Load Washer
My frigidaire front load won't pump ou the water
I have taken the hoses off and ran the pump it turns but sound really rough and sometimes stops for a second, we had a bra wire caught in in awhile back and I am wondering if it has damaged it. It also won't spin.
  • dwilson351 Feb 18, 2009
    Thanks I took it apart there is nothing in there but it sounds rough.
  • 130 Answers
Possibly it did damage it, but it is more likely that something else has become lodged in there again. happens alot on front loaders.
Posted on Feb 18, 2009
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
My frigidaire front load washer stopped working mid-drain. Now the washer will not drain, fill, or spin. No error codes are displayed on the LED. When I set the washer to a given cycle, I hear only a...
It sounds like the pump has stopped and may have sucked a sock or rag into it. May need to pull the washer out, remove the back. Unplug the washer and see if you can manually turn the pump/motor belt. It could also be the motor but I would check to see if they turn. If not, remove the belt and manually try to turn each and see if they turn.
Nov 06, 2017 | Frigidaire ATF6000ES Front Load Washer
My washer stops half way through the cycle and blinks????Frigidaire affinity front load washer for some reason just stop halfway through the cycle sometimes.
Take note if the drain pump is operating. If it stops halfway, it must be stopping for a problem that has arisn, Normally, the water is not being pumped out.
Jun 13, 2010 | Frigidaire Affinity ATF7000E Front Load...
Will not drain pumps little water
Hello,remove the lower front panel....screws to remove are #19 and the panel #18 will drop down a bit and forward to come off.
sometimes coins,zippers,lint,bra under wires will get caught/jammed in the drain pump assembly and stop it from running/working.The hoses can be removed from the pump to check for any foreign objects or the
pump (the part where the pink and white wires are) can be totally removed by unclipping the wire harness and removing the two "5/6" bolts to check the pump assembly itself,The pump can be taken apart to check inside....if needed.The pump assembly is in the front right corner......
Thanks
May 24, 2010 | Frigidaire ATF6000ES Front Load Washer
Front load waher will not drain
Hi, your washer water pump, could be burnt out, or clogged up, but first check drain hose for kink, remove back of machine, locate water pump, device that your drain hose are connected to, remove all hoses, pump from washer, and clean, sometimes foreign objects get into it, and prevent pump impeller from spinning, also check water pump winding (coil) with ohm tester, place tester lead, one on each terminal on pump (motor) if you hear beep sound, pump motor o/k, if not, pump burnt out, replace it, but first remove pump, and clean it. after cleaning replace pump, try machine. you could put drain hose, close to floor, into buck, and water will empty by gravity, if water is not emptying, that's evidence your water pump is block, small object (handkerchief, coins etc.) gets into them, from time to time, first clean your water pump, `and check for kink, in drain hoses. . always disconnect power, before attempting any repairs. good luck.
Aug 13, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a 2 year old frigidaire front load washer.  The spin cycle starts, but only runs really slow.
all washers must drain before will go into high spin.is your's draining?the front loader type's of washers are good for getting the pumps blocked up with stuff that was in our pockets etc....too get to the pump remove the bottom front panel.the pump is the white or tan unit with two hoses to it and two wires on the right side of the washer..there are some bolts retaining the pump to the washer floor.remove and remove hose and drain into a bucket.then clean out pump.if you turn off water at house fill hose's you could put in spin at that point to test.then put all back together.if you need more advise you can email th-u fixya. God bless ,tom
Jan 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Oct 19, 2008 | Frigidaire GLTR1670A Front Load Washer
Washer won't drain and is making a grinding sound
That grinding noise could be something caught in your drain pump.  The fact that it doesn't drain could be that something has lodged in the pump and either stopped the impeller from turning, or has ruined the pump.  This is actually a common problem with the small front load washers.  If you remove the lower panel just under the door the drain pump will located in the front on the right hand side.  You will need to remove the inlet hose from the pump.  This is the hose that runs from the tub to the pump.  Unplug the washer first, and drain any residual water from the tub by using a wet/dry shop vac and attaching it to the drain hose at the standpipe.  If you can manage to pull the water from the washer in this manner, you will avoid a huge mess later.  There's roughly 7 gallons of water in the tub when it is full.  I don't think you would want this much water gushing all over your floor.  With the drain line removed inspect the impeller of the pump for obstructions.  The most common culprit is coins, drill bits, screws and nails.  Even tooth picks and cotton swabs can stop the drain pump if they become lodged.  If you find the pump clogged and manage to clear it, you still may have to replace, however.  Just keep that in mind.  The pumps are usually pretty durable, but depending on how long it's been in it's current condition, it may have ruined the pump motor and/or impeller.  I hope you find this information helpful.  Good luck to you and post back with comments if you have any further questions.
Oct 20, 2007 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool front loading washer
The 02 error code relates to a drain problem. Check that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Regarding the spinning noises and vibration, open washer's rear panel and look for a released or a malfunction shock absorber. Good luck!
Aug 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
