Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
WE LIVE IN A CONDO AND SOMEONE IN THE COMPLEX HAS A hAMPTON bAY CEILING FAN WITH A REMOTE JUST LIKE US. wE MUST BE ON THE SAME FREQUENCY AND WHEN THEY TURN THEIRS ON IT WILL MAKE OURS COME ON WHEN WE HAVE OURS TURNED OFF. WE WOULD LIKE TO KNOW HOW TO CHANGE THE FREQUENCY ON OUR REMOTE TO FIX THIS PROBLEM
  • snf55b Apr 11, 2009
    Hampton Bay Model UC7083T - has same problem as described. How *** I change my frequency so that I do not conflict with my neighbor's remote?
    Sniper:
  • 86 Answers
There should be dip switches in/on both the remote control and the ceiling fan that enable you to change the control frequency. The only thing that you have to ensure is that the two components are set to a matching frequency.
The switches in the remote are located in the battery compartment just above the batteries. Remove the dome on the ceiling fan and you should find the switches for that unit. Just compare the two and match whatever changes you make from one unit to the other.
Posted on Feb 18, 2009
The pull chain for our Hampton Bay Sibley 52" Ceiling fan quit working so we think we need a new light kit???
You just need the switch by the sounds of it.
Hampton Bay Customer Support -Troubleshooting & FAQ ' The Home ...
www.homedepot.com/c/SPC_BRD_HamptonBay_Help
  1. Cached
  2. Similar
Find Hampton Bay customer support, replacement parts, warranty information, troubleshooting and ... Ceiling Fans Patio Furniture Lighting Bath Fans Fireplace
Hampton Bay - Ceiling Fan Parts - Ceiling Fans & Accessories - The ...
www.homedepot.com > ... > Ceiling Fans & Accessories > Ceiling Fan Parts
  1. Cached
Shop our selection of Hampton Bay, Ceiling Fan Parts in the Lighting & Ceiling ... Hampton Bay 3-Light Universal Ceiling Fan Light Kit with Shatter Resistant Bowl .... Fan Light is an ideal choice for replacing worn or outdated fan light fixtures.
Hampton Bay Lighting Parts and Accessories ' eBay
www.ebay.com > ... > Hampton Bay Lighting Parts and Accessories
  1. Cached
  2. Similar
Replaces Hampton Bay and many other similar ceiling fan remote controls. Common replacement for model number UC7078T or FAN-HD with a reverse button.
Hampton Bay Replacement Parts
hamptonlightingadvice.com/hampton-bay-replacement-parts/
  1. Cached
If you have a Hampton Bay product such as a lighting fixture or patio furniture or maybe even some solar lights or ceiling fans then you may need to find a ...
Hampton bay fan and lighting company website store
hamptonbayfanandlighting.net/
  1. Cached
Hampton bay fan and lighting online store. Menu. Skip to content. Hampton bay moved to new ... Hampton bay moved to new website >>>> hampton bay ...
Hampton Bay Ceiling Fan Parts
www.ceilingfansbay.com/hampton-bay-ceiling-fan-parts/
  1. Cached
Do you need help to find a Hampton Bay Ceiling Fan Part? ... known and reputable manufacturer of ceiling fans, bath fans, light fixtures, patio furniture, chandeliers and more. ... Easy Way to Finding the correct Hampton Bay replacement part:.
Hampton Bay Ceiling Fans & Lighting
  1. Cached
If you need a Hampton Bay replacement part, we can help you with that. Here are the most common Hampton Bay replacement parts that people search for, and ...
Lighting Replacement Parts For Your Ceiling Fan
www.ceilingfanreplacementparts.com/hampton_bay_lighting_replacement_parts.html
  1. Cached
  2. Similar
Hampton Bay lighting replacement parts are readily available to let you maintain for many years the beauty and function of your ceiling fans, lamps, chandeliers, ...
Hampton Bay Google Search
Nov 21, 2016 | Hampton Bay Dryers
Remote does not work. Have relaced remote and receiver. Fan and light turn on and off at any time by themself!!
Change the frequency settings. Your neighbor's fan is probably on the same setting you have now. If you didn't have problems before you put in the new receiver, change to original settings.
Aug 24, 2015 | Hampton Bay 46056 Callaway II Ceiling Fan
How to correct a Hampton Bay ceiling fan and light that goes on without using the remote control?
Change the frequency in the receiver & transmitter. Sounds like a neighbor has a remote fan on the same frequency.
Aug 28, 2014 | Hampton Bay Dryers
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
Ceiling fans on same frequency
Originally answered by d0n0r in this question
May 25, 2009 | Universal Remote Control Hampton Bay...
Fan and dimmer remote does not work
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Mar 01, 2009 | Universal Remote Control Hampton Bay...
Remote control replacement.
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for the various brands including Hampton Bay...
Dec 10, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Remote control, changed battery, still nothing
You can also try ebay for OEM replacement fan remotes for various brands including Hampton Bay...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Mind of it's own
your remote and fan is set to someone elses frequency by little toggle switches
you will have to remove fan to where it hangs make sure power off
find the remote sensor inside electric case at ceiling in the fan
this is a dip switch to control frequencies
09c4f2f.jpg you will see something like this adjust the dip switches
means change the dip switch for fan
then on remote open the remote battery pack find the dip switch in there
change those dip switches to the same as in ceiling fan
put fan together and turn back on power
your fan should now not pick up the other frequency of another remote and they have a span of about 50 yards to pick up frequencies
Jun 07, 2008 | Hampton Bay 24002 Ceiling Fan
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
397 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
