Question about Kenmore Dryers
Dryer doesn't run. Turn the Dial and it goes "click,click, click
At first it would start, then shut off. I would turn the timer dial and then it would start up again. Now it just clicks.
  • 547 Answers
Change the timer
Posted on Feb 18, 2009
Dryer is working but does not turn off, when it reaches OFF. It goes passed it. No matter where the dial is set, even the timer section, the dial goes passed the OFF marker.
This model does not have a timer, so what model do you have? This is a electronic panel with push buttons. Is the unit still heating when this happens, or is it just running like anti-winkle (air fluff) setting?
Good Luck
Aug 28, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heats and drys but shuts off intermitantly..sometimes can be started right up, other times turning dial does nothing.. is it the timer dial?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 17, 2011 | Amana ALE643RB Electric Dryer
I bought a house with a Night Sentry Solid State Timer model # EJ341 and have no instructions on setting or programming the unit.
rapid Programming.
1. Move control lever to OFFCLEAR for at least 5 seconds
• red indicator light goes off
• all time settings are
erased.
2. Move control lever to ON.
• red indicator light will start
flashing.
3. Check a clock; then turn pushbutton time dial clockwise at least one click.
• stop at the half hour nearest to present time (note
AM or PM).
Note: When turning pushbutton time dial, do NOT
accidentally PRESS at the same time.
4. Press pushbutton time dial once to enter present time.
• red indicator light goes off (present time has been
recorded).
5. Turn pushbutton time dial clockwise to desired
ON time.
• red indicator light blinks with each click.
6. Press pushbutton to enter ON time.
• controlled light(s) will turn on.
7. Turn pushbutton time dial clockwise to desired
OFF time.
8. Press pushbutton time dial to enter OFF time.
• controlled light(s) turn off.
9. Repeat 5-8 for other on/off times.
10.Turn pushbutton time dial for at least 2 more turns
from the first ON time to complete this program
• red indicator light will turn on and stay on (steady
light means timer is in automatic).
Note: Pushbutton time dial does not turn
automatically after setting to indicate time of day
Aug 22, 2010 | Hardware & Accessories
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Dryre won't shut off
please remove vent line from dryer,turn on see if timer starts to advance if so...possible vent line clogged...or dryer has plugged with lint..call if need assistance michael doctor airr appl.repair 843-384-8474
Mar 26, 2010 | Dryers
Dryer will not turn off aafter it's 40 minute cycle.it will start over with 1 hour 22 minute cycle
You should check your thermostats, they can cause this problem.
Look for the air tube that goes from the blower to the drum, this is where the thermostats are normally located and the heating coil is normally located there also.
Hope this helps
Sep 30, 2009 | Maytag Dryers
Starts automatically when I set the timer
This could be a problem with the start button switch (it should click when pressed/released) or with the switch on the motor.
May 20, 2009 | Dryers
Dryer runs and doesn't stop based on the selected dry time
Check the connections to the timer dial. If all connected, replace the timer. Should solve the issue
May 08, 2009 | Dryers
Dryers Logo
56 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
