Question about Panasonic DVD-F87 Multi-disc DVD Player
Replace transverse optical unit in panasonic f87
I have located a number of suppliers for the transverse unit, but do not know how to replace it... (part no. RAE2008W-S) no service manuals to show how to disassemble the f87 and replace same
2 Suggested Answers
  • 192 Answers
SOURCE: my panasonic dvd/cd player model number dvd-F87 .
try to changed the settings of that..
Posted on Oct 14, 2010
One transistor has blown there is no numbers they blown away sony hbd-dz350
Here is the manual with the schematics for the unit. Unforunately it is large but I don't know which unit in the system you had the transistor blow. It will show you what the part specifications are for it and you can order a new one at an electronics parts supplier. I don't know if you have the ability to replace that yourself or not. If not someone at the store may be able to do it or direct you to someone who can. If the system is still under warranty, I highly recommend you have it fixed under the warranty. Here are the schematics pages:
Good luck
Nov 04, 2015 | Sony Audio Players & Recorders
Can I get a owners manual
Best bet is to visit manufacturer web site for manual download
Sep 04, 2015 | Saws
America Standard heat pump model WCy036- turns on but fan on blower not working???? Any manual anywhere I can download
While I do not know about manual the fan is located on top of unit and goes bad the check s simple if you know electricity first pull breaker on unit using a multimeterrible sett on volts push leads into 2 wires going to fan motor about replace breaker staking clear if meter show
voltage pull breaker remove meter an you fan motor is shot no voltage freon or other technical problem call AC GUY if fan motor dead call refrigeration supplier name model an serial number simple unbolt takeoff fan and two wires to replace ALWAYS PULBRE
AKER BEFORE working on any electricAl applia
Aug 16, 2015 | Heating & Cooling
Model CX-NMT720 replace tape drive belt/belts
If the model does not appear in the PRB Pdf file then you will need to measure and subtract 5% and order those from a supplier. The service manual will not tell you how to put them in it just shows location. You need a speed test tape and frequency counter to set the speed anyway- best done by a Technician.
Nov 30, 2014 | Audio Players & Recorders
Hot exactly do I remove the trany in my 03 cavalier
Front wheel drive, Transverse engine? chances are it requires a lift to drop the engine/transmission unit from below. Chilton makes affordable manuals, oh, but they cost money.
Nov 05, 2014 | PIAA 2003 Chevy Cavalier - All Cavalier...
I need an intake runner module but can't afford $400.00. Anybody know what cars might be interchangable?
Several suggestions. Try when you find correct part number. Also Ebay and Amazon. Salvage yards would be good. is an online National locator service for Salvage parts which has free Request feature and results show many details. Details include Photo, Part grade, Price, Warranty, location. Could easily give you 100 results.
As with parts store and Salvage yards, some have cross-references and some do not look up alternate part numbers. Can tell you that with Ford parts, engineering changes reflect in some part numbers. Typically an "A" is a first issue, B,C,D etc. are later changes and THAT Engineering numbers are not the exact match to a Ford Part number. So you can have different Engineering numbers be the same Part number.
Why? Supplier deviations. There can be modifications to the original design that suits the Supplier due to machinery problems, material costs, or to simplify assembly. Once approved by Ford, the part is assigned a different Engineering number from that point on; yet it is still the correct part for the Ford Part number. Basically the Engineering number is meant to be an internal number and the Part number is external.
So if you get a part with molded numbers that are different, it is often the sticker or soft label which matters.
Sep 23, 2013 | 1998 Ford Contour
What is the part number for the charcoal filter.
For a Frigidaire FMV156EM (which is made by Sharp), the charcoal filter is Sharp part number RK-240 also known as PFIL-B016MRE0.
The first part shows up in simple Google searches, so feel free to pick a vendor that shows up there.
But my best suppliers don't show it, and the second part number is only in the service manual, so it must be a proprietary number.
Otherwise, you can search for your nearest service / parts supplier for Frigidaire here.
The owner's manual is here, and that will help you in changing it.
Dec 31, 2010 | Frigidaire FMV156EM Microwave Oven
We have a Notevision Sharp LCD projector, PG-C30XU and can't figure out how to open up the insides of the projector to replace the fuse. Or even where to get the replacement fuse.
Above is a download for your service and repair manual, this will show you everything you need to know to do with this printer.
Replacement fuses, and parts, are easy to obtain, simply Google the parts number, obtained from the manual, and you will find a number of suppliers, simply choose one you like, and get it shipped to you.
Nov 15, 2010 | Sharp Notevision PG-C30XU Multimedia...
Thank you for your assistance in locating a manual for my Leisure Bay spa. I do not know where to look for the model number to know wh8ch manual I should choose. Do you know where they are normally...
Model numbers are normally located in very close proximity of the electrical connections where the electrician hooks up his wires to your unit....and/or where the serviceman accesses your units controls for service/repair.
I hope you find this to be very helpful to you moving forward. :-)
May 17, 2010 | Heating & Cooling
Panasonic DVD-F87 Multi-disc DVD Player Logo
52 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
