Question about Toshiba 43H70 43" Rear Projection Television
Toshiba HD made a popping sound and went out.
I have a Toshiba HD ready 57" projection TV. It is about 4-5 years old. It is widescreen and It was in my rec room and it made a popping sound and went out. Now it won't turn on. anyt ideas?
  • keli1 Mar 03, 2009
    I have the same problem I have a Toshiba 32 inch tv, first thing in the morning the popping is crazy. sometimes at night is goes off as well. Is it time to get a new TV. What is causing the popping noise.
Check the lamp to see if it popped. Try replacing it. Also check the web for class action law suit for these sets, Toshiba has an extended warranty for lamps for certain units.
Posted on Feb 18, 2009
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba Tv - Does it have a digital tuner?
That unit has a NTSC tuner. May be HD Ready but it does not have a digital tuner. Unless you live quiet close to a local Broadcaster, rabbit ears would be useless.
The only way you would be able to get HD is using a HD Set Top Box, HD Satellite System,
or HD Cable BOX, using the Componet or HDMI inputs.
Hope this helps
Skyassoc
Jun 22, 2009 | Televison & Video
Toshiba 61H70 projection TV. Perfect picture but the sound suddently stopped working. Tried all on screen settings and still no sound. Set is 8 years old but relatively few hours. Is it worth repairing?...
it sounds like the soundboard went out on the tv..its probably worth fixing but you have to know what you are doing if you do it on your own.it could be something more minor too but not sure
Feb 24, 2009 | Toshiba 57H81 57" Rear Projection...
Red light flashing while green light stays on
I have the same TV, your projection bulb has quit/failed.
A loud pop was heard and the picture has gone followed by a red led fault light clicking on and off.
if your tv is less than 1 year old, and you registered it with Toshiba, you could qualify for a free replacement.
otherwise expect to pay 200.00 for a new bulb from Toshiba.
only good thing is you can replace it yourself, only tool needed is a phillips screwdriver.
you can check EbaY for prices less than 175.00 to 150.00
i am on my 3rd bulb within 4 years....
good luck!
Aug 19, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba tv - no picture
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 04, 2008 | Toshiba 57H81 57" Rear Projection...
SAMSUNG 19 INCH HD READY WIDESCREEN LCD TV LE19R71BX/XEU
We will need a list of the everything you tried.
Usually, this kind of thing is caused by hookup errors.
Dec 27, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Menu, volume and channel emblems will not show up
take your set to a tech the tv system control circuit might have damage, that circuit controls OSD,channel memory. it is an ic that controls that circuit along with other components.good luck.
Mar 26, 2007 | Toshiba 43H70 43" Rear Projection...
Toshiba 43H70 43" Rear Projection Television Logo
176 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
