Question about Whirlpool GU2400XTP Built-in Dishwasher
Ran dishwasher, we to work, came home, no power, water in bottom. Breaker is not tripped, power to rest of kitchen
    Scholar:
  • 135 Answers
Although breaker has not tripped it is still worth changing the fuse in the dishwasher plug.
Nothing to lose for a few pennies.
Posted on Feb 18, 2009
Why does my Fisher and Paykel DD605SS stall part way through wash cycle?
I'm not sure of this, because the manual does not have an error with a E. I can fine error F4. It says it encountered a faulty temperature sensor or element. If the heating element burned through the night you circuit breaker tripped (Sure it was not the ground fault circuit breaker?), then the dish washer can't heat the water, so the program can't continue. The program stops (waits) till the chosen temp is reached. If the water stays cold the program can't go on.
So also check the heater in the machine. I hope you are aware everything in the machine runs on high (or at least dangerous) voltages, so be careful not to work in the machine when it is still connected.
Jun 15, 2014 | Fisher and Paykel Dishwashers
LG Dishwasher LD-1420T1 Tripping the main Power Board
Looks like the pump motor is drawing lot of current and tripping the circuit breaker. Need to check if there is any water inside it. Or simply the capacitor is leaky and causes motor to draw current.
See this part.
http://shop.onlineappliancespares.com.au/part/4681ea2002f-134640/43518
Apr 07, 2014 | LG Dishwashers
Please help me fix my electrolux dishwasher, water is building up at the bottom and its not working
Wendy, sounds like the drain pump or the actuator for it has failed. If you hear the pump motor hum, but it does not empty the water, it may be jammed with some debris. To access all of the mechanical workings, you will need to remove the lower access/kick plate cover, on the bottom of the front of the dishwasher cabinet. You may want to empty most of the water out of the tub by hand, before you attempt to work on it. Also, check the circuit breaker for the dishwasher in your home's circuit breaker panel, to make sure it has tripped. If it has, reset it to see if the dishwasher will start running again. Just make sure it's in the drain water cycle.
Mar 22, 2011 | Grilling
All of a sudden, no power. will not start, no warning.
Before looking into your built-in dishwasher as the problem, check your main electrical panel to see if you have tripped a circuit breaker. If not, you may have tripped a GFI receptacle located on or around your kitchen counter.  If so, reset it! Then try the dishwasher. However, if this IS the problem, this may become an ongoing problem. I agree with (and its code) having a GFI breaker in your kitchen.  But what I don't agree with is when the contractor/electrician who installed this, didn't take into consideration that when these GFI's are put in series with other receptacles (for added protection) in the kitchen, they trip more easily when plugged in with certain appliances because of the motors (eg. refrigerators, dishwashers, etc.) in them. The GFI's sole purpose is for protecting you around the sink where there's running water. It trips on milliamps so you won't get electrocuted around the sink. Also, if you have other appliances running at the same time the dishwasher's running, makes them more susceptible to trip. So in conclusion, first check for power. Second, check for GFI breaker (or vice versa). I believe you should find your problem here. If so, reset it and wait to see how and when this does it again. GFI breaker's are sensitive breakers. They tend to wear out before a regular outlet (receptacle) does. Not knowing how long and old this (GFI) receptacle is, I'd replace that if it happens more frequently. This usually does the trick. I hope it's not your built-in dishwasher. If so, feel free to contact me again, and I'll help you with that too. Good Luck with this, and I hope you get everything back in working order. Take care, Jim
May 22, 2010 | KitchenAid 24 in. KUDS02FR Built-in...
Kitchen aid Model#KUDSO1DLWH3, stopped working. No lights, No function. Circuit breaker ok. water in bottom of tub
CHECK FOR VOLTAGE TO UNIT, CHECK THE WALL SWITCHES, CHECK THE GFI OUTLETS FOR TRIPPED.
Mar 09, 2010 | Dishwashers
Works then no power Kenmore 16352
first thought would be a loose connection in the junction box under the dishwasher.
Nov 27, 2008 | Kenmore 24 in. 16352 / 16354 / 16359...
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Oct 21, 2008 | Dishwashers
No power, water in machine
Depending on how your DW is wired.. it could be plugged into a receptacle like any other appliance or hard wired directly from your circuit breaker box.. I would check to see if you have any circuit breakers tripped or fuses blown... to verify that you have power.. assuming you do... and because you had water in the base .. chances are your drain filter was clogged that leads water to the pump.. or the pump itself is clogged or defective.. Try power cycling the system by either unplugging it or switching off the breaker or fuse feeding it power.. Hope that helps
Aug 27, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
360 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
