Question about Insignia Digital-to-Analog Converter for Analog TVs
Unresponsive RCA Digital Converter
We hooked up our RCA digital converter box a few months ago but haven't used it to watch television since we live in a rural area and not much came in anyway. I heard that we might actually receive new channels if I do another scan but when I went to run the scan, nothing happened. The box doesn't turn off or on, the remote has no affect, nothing. The picture just shows up to read 5:36 pm (it's 10 am), with a fuzzy mix of colors around it that do not move or anything.
Do I need to unplug it and hook it up all over again or is there something else I need to connect or punch in?
  • 88 Answers
You may need to change your antenna for digital reception. Make sure the outlet you are using for the converter box has power to it.if that does not solve it you may have defective box.
biigg53566
Posted on Feb 19, 2009
Do i need a digital converter box to watch tv with an antenna with model 46la55r120q
According to the user's manual, the TV can receive and decode analog and digital TV signals, so no, you should not need a digital converter box. During the channel scan it will search for analog channels first, then digital ones.
Oct 23, 2015 | RCA Televison & Video
Can I connect two tv to one television converter box to watch local channels
If neither TV has a digital TV tuner, you will only be able to watch one channel on both TVs with one converter box. You will also need some sort of RF repeater if you want the person in the second room to change the station without moving the box. You will need a splitter/amplifier connected to the converter box TV out. (I'll assume you are using the coax out.) If you will only watch one TV at a time, then use an A/B switch on the converter box TV out.
If one of the TVs has a digital tuner, put the splitter/amplifier between the antenna and the converter box and the TV with the digital tuner.
Note: amplifier/splitters and switches do fail. If you get a "no signal" message, take out the splitter and connect the converter box directly to the antenna or one of the TVs depending on your set up.
I hope this helps.
(I use an A/B switch between the antenna and the TV and converter box for feeding an old VCR/DVD recorder.)
Mar 08, 2013 | Televison & Video
What is the code for an apex digital converter box?
Hello
You haven't specified the exact model number of your RCA remote control. Three device remotes for RCA is in many model numbers. If it is RCA Systemlink-3 remote control, there is no setup code for Apex Digital Converter Box. OK.
Oct 21, 2011 | RCA 3-Device Universal Remote
I need a 3 digit code for RCA converter box for a Orion tv.
Hello
You haven't given a clear problem post ebefore me. You have only give the model number and brand name of your TV only. Not give the model number of your RCA converter box. Yet i posts a solution to your problem, assuming that your RCA Converter box model number is " DTA 800B1 " The three digit setup codes for Orion TV with this RCA converter box are: 029, 189, 200
ok
gopakumarg43
Oct 04, 2011 | Orion STV2763 27" TV
In our new digital world ... can a Durabrand model DU1901A function without a converter box?
Hi.
Unfortunately, your tv is NOT digital ready, so if you want to watch anything, you will need a digital convertre box to get any channels, otherwise it's only good as a screen to hook up dvd's and video games to it.
Sorry about that, but this new fangled electronic age we live in has made probably 250,000,000 tv's useless without some sort of converter device.
I hope this helps you out.
If you do go to get a converter box, I would just go with one of the inexpensive ones from Wal-Mart.
Rca and Magnavox have boxes for around 30-40 dollars.
Good luck to you, and have a good day.
May 05, 2011 | Durabrand DWT1905 TV
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
So you are telling me I need a digital converter for this TV to g
Who was not watching the months of public service announcements? You need a Digital-to-Analog (ATSC-to-NTSC) converter box to receive over-the-air (OTA) signals in most parts of the country. You do not need one for most cable and satellite box outputs--they are NTSC or HDMI. Some low-power, typically religious, stations are still analog. Note OTA may be high definition (HD) or standard resolution (SD) but will be digital.
To get HD on your HD set you must have OTA (HD TV tuner, not converter), cable (QAM TV receiver), satellite (HDMI or 5-wire RCA),or Blu-Ray with HDMI or RCA.
-Ken
Aug 18, 2009 | Hitachi 46F510 46" Projection HDTV
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
How do I scan for channels with my RCA converter box
The remote should have a scan button on it.
then the screen go thru it process and it should say done
Feb 18, 2009 | Zenith C27V36 27" TV
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
73 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
