Question about Maytag MDE308DAYW Electric Dryer
No start how do i get to the motor and/or belt on this model druer and how to determine if it is the motor blown and not the switch
  • 1 more comment
  • brown2181 Feb 18, 2009
    is the ticking occur all the way around or just at the end points of the cycle
    yeah it doesnt tick in the middle of the cycle so should i change out the timer instead
  • brown2181 May 25, 2009
    the problem ended up being the thermal fuse needing replaced
    Guru:
  • 1,738 Answers
New dryers comes apart from in the front. There should be two phillips head screw, or star bit screw. You will a loud noise coming from the motor and that when you know. To get a new mortor take the model number and the motor to the local dealer and they should be able to help then.
Posted on Aug 10, 2009
  • 547 Answers
When you turn the dial can you here ticking? if yes it's the motor if no it's the timer
Posted on Feb 18, 2009
  • albert getty
    albert getty Feb 18, 2009
    in the center of cycle you should still here it
  • albert getty
    change the timer
Clothes dryer tub does not turn
make this test and fix it. Merry Christmas
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Belt
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. If you hear the motor running but it does not tumble it is most likely the belt.
Motor
If the dryer motor only hums when you press the Start button, the motor may be burned out.
Remove the belt.
Check for obstructions in the blower fan housing.
Dec 19, 2013 | Speed Queen Dryers
Kenmore 62922 electric dryer
follow this steps and fix it. God bless you
Thermal Fuse
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Enter your model number to see parts for your dryer.
Help me find my model number
Start Switch
The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Most door switches will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Drive Motor
On most dryers the drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt
On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Thermal Cut Out Fuse Kit
Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Incoming Power Problem
If the dryer won't start, check to make certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch
If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Main Control Board
The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer
The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 01, 2013 | Dryers
When you hit any button it turns on and the next button shuts it off
Thermal Fuse
Start Switch
Door Switch
Drive Motor
Drive Belt
Belt Switch
Main Control Board
Timer
Jul 09, 2013 | Kenmore Elite Oasis 7808 Gas Dryer
The dryer will not start. there is power but when we press the start button nothing happens. one of my children made the barrel turn with her hand and herd a noise (klunk) as if something fell inside and...
The drum belt may have slipped off the idler pulley. On some dryer models, if the belt loses tension, there is a drum safety switch that disables the drive motor. This is known as a broken belt switch. This prevents the belt from wrapping around the drive motor shaft and possibly damaging the motor in the event of a belt snapping. If you post back with your complete MODEL NUMBER, I may be able to assist you with determining whether or not you have a belt problem. The model number is usually located on a nameplate around the door opening, or on the back of the operator control panel. I hope this helps you.
Jul 26, 2011 | Dryers
My whirlpool portable 3 cycle druer stopped tumbling is there a belt because I,ve taken it apart and can,t find it
The belt may have gotten wrapped up in the outer shell of the drum. In any event, armed with the Model # and Serial #, you can purchase the replacement belt from any local appliance dealer's parts dept. Since it's already been taken apart, you're one step ahead of what you would have needed to do.
Hope this helped you.
Mar 02, 2011 | Heating & Cooling
I have a Kenmore 600 series Electric dryer that wont start. The light inside is on, so I know it's getting power.
The most common cause of a dryer that will not start, is a blown thermal fuse, bad power cord, or a broken drum belt. If the voltage at the wall receptacle is correct, check the voltage again at the terminal block where it connects to the dryer. Make sure you UNPLUG the dryer and remove the the small access cover where the power cord is installed. If good, the problem is INTERNAL to the dryer. If bad, you need to replace your power cord.
If the problem is internal, the thermal fuse will be mounted on the blower fan housing. It is a small plastic looking component (usually white in color) with two wires attached to it. Disconnect the wires before taking any resistance checks. If the fuse is good, it should read something close to zero ohms. If bad, you will read an infinite reading. These fuses DO NOT reset and must be replaced if bad.
Some dryer's are equipped with a "Broken Belt Switch", that disables the dryer from running if the drive belt breaks. This keeps the belt from becoming wrapped around the drive motor shaft and causing damage to the motor. Since you did not include a complete model number, I cannot verify if your dryer is equipped in this manner.
Another cause of a dryer that will not turn on, is a broken door switch. An easy method to test the switch is to open the door and press by hand. If the dryer drum light is working, you should be able to toggle the light on and off. If the switch is found to be defective, it must be replaced.
The least common failure item is a defective drive motor. Each one of these dryers should come with some literature inside the operator console that includes a wiring diagram. The diagram will indicate which wires at the motor connector to measure the motor windings.
NOTE: All the drive motors on these appliances also have a centrifugal switch that, once the start button is pushed and the motor begins to run, will latch as a closed circuit and keep the motor running. Some of these switches are external to the motor and can easily be replaced. Some are internal and require a complete motor replacement. Again, your model number will determine how the dryer is configured.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have competitive pricing, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations that you can use to locate and properly identify any parts you may need. If the model number is correct, the part number you may need are as follows:
If you have any questions about these repairs, or need instructions on how to access any of these components, please post back with your complete MODEL NUMBER (located on a nameplate around the door opening) and let me know. I hope this helps you.
Oct 21, 2010 | Kenmore 600 6965 Electric Dryer
Dryer will not start. Power is OK.
Sounds like your problem may be a broken belt.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the belt is not the problem then you have exposed the motor for further checks. If the motor is ok, then I would look at the start switch or the timer switch.
Good luck,
I hope this helps
Oct 08, 2009 | Kenmore Dryers
My druer is heating but the drum wont spin
either the motor is defective or the drum belt is broken or off the pulleys, if you can't hear the motor start and run w/o belt attached and it just buzzes the motor start cap could be bad
Sep 30, 2009 | Dryers
Roper dryer won't start
Since you did not post a model number it is difficult to determine what features your dryer has. However, here are some of the most common causes of a dryer that will not start:
1. Blown Thermal Fuse. Located on the blower fan assembly and is a white plastic looking component with two wires on it. A measurement across the fuse should read a short (0 ohms) if good. Make sure all measurements are taken with the dryer unplugged and the wires disconnected from the fuse.
2. Broken dryer belt. Some dryers are equipped with a broken belt switch that will shut the dryer off in the event of a broken belt. This prevents the belt from wrapping around the drive motor shaft. You will need to open the dryer and do a visual check to determine if the belt is still in one piece around the drum.
3. Broken door latch. You can usually tell if the latch is working properly by leaving the door open and toggling it with your hand. If the drum light shuts off when depressed, more than likely you don't have a door latch problem.
4. Bad centrifugal switch on the drive motor. The drive motor has a centrifugal switch that engages when the motor begins to spin. Some dryer motors have a separate centrifugal switch that can be replaced, while others have an internal switch which requires the entire replacement of the drive motor.
5. Bad drive motor. Commonly caused by failure of the internal centrifugal switch or bad motor windings. I have found the main connector plug on the motor loose at times causing the dryer to fail too.
6. Bad start switch on the control panel.
7. Bad control board on the control panel (if equipped). Not all dryers have a control board. Some only use a simple start switch.
I hope I've given you enough items to think about. If you have questions, or require additional assistance, please post back with your model number so that I may be able to provide you with better assistance. I hope this helps.
Sep 19, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Won't Heat -Maytag Gas Dryer Model MD-4 Intellidryer
Once I paid my gas bill--mine started working normally again.
Jan 30, 2008 | Dryers
Maytag MDE308DAYW Electric Dryer Logo
141 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
