Please i have a problem for deep freeze - Computers & Internet
My freezer in cold in the middle and not that cold in the corners. that is when it's closed. it's five yoears old.
Posted on Mar 04, 2009
How to remove deep freeze from my PC that has been downlaoded from the internet? please help
hi! you must look for the same version of your deep freeze on the web, then install to remove the old version of deep freeze.
Jun 30, 2011 | Cycling
My deepfreeze didn't show in my taskbar how i can disable it?
I understand that you would like to disable the deepfreeze software installed on the computer.
One or more methods can be employed to enable/disable (Freeze/Thaw) Deep Freeze depending on the version being used.
A) Locally at the workstation (Deep Freeze Standard and Enterprise):
The following steps can be used to disable (Thaw) Deep Freeze:
  1. Hold down the SHIFT key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6. A Password dialog is displayed.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering a password. The Boot Options dialog is displayed.
  3. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. The same steps can be used to enable (Freeze) Deep Freeze. The only change is to select "Boot Frozen" instead of "Boot Thawed".
B) Remotely via Deep Freeze Command Line Control (Deep Freeze Enterprise only):
Deep Freeze Command Line Control (DFC.EXE) can be used to Thaw/Freeze Deep Freeze through a script or batch file. More information about using this utility can be found in the Deep Freeze Enterprise user guide available at:
http://www.faronics.com/documents/DF6Ent_Manual.pdf
C) Remotely via the Enterprise Console (Deep Freeze Enterprise only):
The Deep Freeze Enterprise Console can be used to Thaw/Freeze a workstation using the following steps:
  1. Select the workstations to Thaw/Freeze.
  2. Click the "Reboot in Thawed state" button to Thaw the selected workstations. The workstations should reboot and appear in the Console in a Thawed state.
  3. Click the "Reboot in Frozen state" button to Freeze the selected workstations. The workstations should reboot and appear in the Console in a Frozen state.
Please try the steps and I am sure you would be able to disable the deepfreeze software.
Apr 20, 2011 | Faronics Anti-Executable Standard
I installed my deep freeze software in my laptop.now i forgot that password. so really i cant store anything in my laptop.
Hi!
Sorry I was unable to provide you exact help on this one as I don't know the deep freeze version you are using but you may want to try these steps, if it doesn't work out, please coordinate with us with the version of the deep freeze.
For Deep Freeze Enterprise:
  1. Open the Deep Freeze login dialog on the workstation for which you need to generate the OTP.
  2. Write down the Token code which is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered):
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options available to assist you.
Or if you may want, you can also back up all your files then reformat the computer. Thanks for reading my suggestions.
Hope this helps even a bit.
Apr 17, 2011 | Computers & Internet
I use deep freeze 6.53 utility but I have to uninstall but the deep freeze program still running, please help me
you have to "thaw" deep freeze first:
push and hold down shift key then locate deep freeze icon (near the time in the bottom on the right) and double clic on it
clic ok (or enter password and clic ok) on the window now opened
then select "boot thawed" and confirm with "ok" and reboot PC
when Pc restarts you will see deep freeze marked by a red cross and now you have to run the original installation file (the same you used to install) and select unistall then PC reboot automatically
Feb 05, 2011 | AnchorFree Expat Shield
I have window s 7 on my pc & I have deep freeze 7 installed on it and i deep frozen my drive c,but after some virus problem my all drive have been deep freezed and now the deep freeze program not...
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Please comment if the information has been helpful. Thank you and regards.
Aug 25, 2010 | Computers & Internet
Remove deep freeze from computer
To uninstall:
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Aug 19, 2010 | Computers & Internet
How to uninstall deep freeze from my pc
(Please let us know if you find the following has been useful.)
In order to uninstall it, you need to disable Deep Freeze first. To do that, please follow the steps below:
  1. Hold down the shift key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6.
  3. If you have not yet entered a password you should be able to click OK without entering a password.
  4. The Boot Options dialog is displayed. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
  5. Reboot your computer. After the computer reboots, you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
I hope this solves your issue. Regards.
I have a problem in deep freeze.i clone my hard disk before i disable deep freeze so in my new disk i cant install new deep freeze because the old freeze is in the pc...when i press shift+ctr+alt+f6...
hi dear... try to select boot thawed and restart your pc then click again the deepfreeze.exe and then click un-install option maybe it can help you dude...happy new year...
Dec 13, 2009 | Computers & Internet
While installing deep freeze my system rebooted and then some error happened. following which it kept on rebooting couple of times, so i used system restore setting to run it. when the system recovered i...
This is the coomon error of the deep freeze . I you can not access deep freeze then download deep unfreezer from http://www.brothersoft.com/d.php?soft_id=171878&url=http%3A%2F%2Fusfiles.brothersoft.com%2Futilities%2Fmiscellaneous%2Funfreeze_quicksetup.exe
Then disable deep freeze with out password after that use the same istaller to unistall the deep freeze which you have used to install .
Nov 02, 2009 | Computers & Internet
How to uninstall deep freeze from your pc?
To uninstall:
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
