Question about Samsung TXN3275HF 32" TV
Rca big screen, no power light,, dead!
Wont do anything,,i have checked power in to the board and
the fuse,,i dont even get the flashing light on the front panel.
its a 52 inch rca model # d52w15byx1
hdtv. i sure would like to get this working and learn a little
something about it along the way.
thanks very much for any help
you can give me.......rowe.
My TXN3275HF will not power on. I replaced the fuse and the power went on and then the fuse blew again. I cannot find just a replacement power supply everyone wants to sell me a whole new board and components. Is that my only hope, or might it be something simpler? Thank you.
3 Suggested Answers
SOURCE: dead Samsung txr 3079 HDTV
Check the small glass fuse on the power supply. I found a close match at Radio Shack for $4.00.
Good luck
Posted on Nov 29, 2009
  • 100 Answers
SOURCE: 1 year ol 52 inch flat screen with new power supply cycling.
Still sounds like a power supply issue would it still be under repairers warranty
Posted on Jan 07, 2010
My RCA L42WD22 flat screen will not power on after being turned off for an hour. When I tried to power it on the green light comes on, and I have a flash of a picture, then a black/blank screen & a...
Take the tv apart.The tv power supply board,that the board,have power a/c cord plug into it.That the power supply board,check component parts like capacitors,see if it leaking gases,these capacitors are dead.Capacitors they'll alway bulges up on it tops or puff up on it tops.Have tools like soldering iron and solders?Know basic electronic and soldering?Replaced these dead capacitors will get power to ur tv back.Or tries websites like Shopjkimmy.com to buy a whole refurbish power supply board for the replacement.
Jun 15, 2011 | RCA L42WD22 42 in. LCD Television
No power at all no lights or anything. replaced the power fuse which was blown still no power rca hd56w66 also replced dp410&dp411 diodes and the fl100 fuse
The whole dawn power supply board is shorted and dead.U have the equipments,a good trouble shooting and electronic skills,trouble shoot all those transformers out put,check all the primary and secondary out put of those coils of those power transformers?Some of those power tranformers are dead needed replacement.Or try website like Tvrepairworld.com to buy a whole refurbish power supply board for the replacement
Nov 07, 2010 | RCA HD56W66 56" HDTV
MY RCA D52W20 52" WONT TURN ON!!!!!
Check the fuse on the AC filter board. If you trace the power cord into where it plugs in on the small skinny board located on the right side when looking in the rear there is a fuse on that board. If its completely dead I would suspect that fuse.
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
Ck capacitor cp150 2200uf 16 volts if bad 2 more in same circuit also needs to be replaced 220uf 35v.ck second ribbon connector on deflection board make sure it is in correctly,or set will not come on.
Dec 18, 2008 | RCA HD52W59 HDTV Projection Television
My RCA TV just stopped working?
ok completly dead with no lights. this is indication of certain cuircit power loss. the main procesor is not receiving power. If i had it in my shop i would TRack the power. or backtrack the ac from the cord comes in through the courd and through the main fuse. then is converted to dc. 360 volts thats wherei would start. Now this is converted to 5, 3, and 7 volts. with regulators. which could be what was mention. I would recomend another tech. WARNING this set can hold that 360 volts even unpluged
Dec 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 32" wont turn on
It sounds like you may have a bad Horizontal Output Transistor (HOT) and/or a bad Flyback Transformer. The set is trying to start as indicated by the flashing light, but an internal fault is shutting it down right away. It could also be the Power Supply circuit. A 32in. set is not cheap to replace so it may be worth finding a repair technitian and at least getting a quote. The Flyback is the most expensive part, the others are minimal. If it is one of the above problems it could easily be repaired by a qualified technitian.
Mar 11, 2008 | RCA F32650 32" TV
43uwx10b hitachi big screen
Check and see if lights on board in back of set, if non then look for fuses in power supply.
Sep 14, 2007 | Televison & Video
Samsung TXN3275HF 32" TV Logo
44 people viewed this question
Jerry Greenberg
Jerry Greenberg
