Question about Simrad Ac10 Course Computer
Simrad ac10 current overload
I am having problems with my simrad ap16 autopilot system. when i put the control unit on auto all is ok, but if the boat deviates from its course or i adjust the course and the system automatically tries to compensate with a rudder change, the control unit alarm sounds and the screen reads 'ACXX CURRENT OVERLOAD.' here is what i have done thus far -checked ALL connections in the system (drive unit, rudder feedback, control unit, and computer) which are fine. removed the drive unit (simrad rpu80 reversible pump) checked the brushes which are fine and cleaned the armiture and brushes. i reattached the pump, thoroughly bled the system, and even replaced the power cable from the drive unit to the computer because there was some corrosion. checked the 15amp fuse in the computer to see if it blew and it did not. checked all voltage in the system and it is exactly at 13.6V (where my charging system maintains the charge of the 2 - 8D house batteries). my next step is to disconnect the drive unit from the computer and see if i still get the ACXX current overload readout. i cannot find fault at all in the drive unit or rudder feedback unit. i am thinking the problem exists in the autopilot computer. can you help at all? any feedback is much appreciated.
I think the AC10 is maxed out at 15 amps while the AC42 goes to 30 amps. Iknow the AC10 is better with solenoid systems and the AC42 for reversing motors.
Posted on Oct 16, 2012
  • 111 Answers
Normally this is the electric motor causing this problem. Just went on a call and had the same thing. Checked voltage coming from the AC unit to the motor and had 12 vdc then put a new one in it's place and it solved the problem. You don't have to change the pump portion, just change the motor itself. Indeed you will have fluid leaking but many times it's better than plumbing in a new pump.
Posted on Feb 01, 2010
Turn on normally, go to press auto.... nothing
Hi Ty
This sounds to me like a cabling problem. There is enough "horsepower" to turn the unit on, but the increased current required to actually run the thing isn't as robust as it needs to be.
I would start by checking the connections at the panel or battery. Make sure these are absolutely pristine. (i.e. Clean and tight) Pay particular attention to the terminals and/or crimp connectors, whichever are used. It doesn't take much corrosion here to render the autopilot inoperable. Let me know how you make out.
Apr 14, 2015 | Navico Simrad AP16 Autopilot for Inboard...
My Ap16 Simrad control head died. Any idea of as to 1) where I might get it repaired and/or 2) where I might find a replacement?
Hi John
Boy, you're up against it on this one. The AP16 is a pretty old unit for sure. Here's the link to your owners manual.
I've come across one instance in my experience where although there was enough power showing to the control head, because of corrosion and broken wire strands, there simply was too much voltage drop and not enough current flow for the unit to function when it was turned on. After cutting back/fixing the soldered connections and reconnecting the cable, the unit was good to go.
I hope this information is able to help you out.
Good luck.
You MIGHT get some joy contacting Simrad tech. at 1 800 628 4487
if you're in the US. If not, here's the link to their support page.
Dec 08, 2014 | Navico Simrad AP16 Autopilot for Inboard...
Why does my simrad ap16 say initializing and doesn't do anything else?
The fact that initialization cannot complete the task at hand is an indicator the device is not capable of accepting new instructions, the circuit prevents reestablishing current instructions from making changes to the unit, or you may need to pay for services to unlock various codes.
May 10, 2014 | Simrad AP16 Second Station
I have a Simrad hydraulic drive HLD2000L autopilot on my boat. I can not find the recommended ISO VG 32 oil. Are there any substitutes that can be used until I find he correct oil? PS I am in the...
International Standardization Organization (ISO) established a viscosity grading (VG) system for lubricants. According to the system way lubricants are designated by the letters ISO followed by a number equal to the oil viscosity measured in centistokes at 40°C (104°F): ISO VG 32. Any atf, thf, stou, ps- fluid or aw32 hydraulic oil. Visit the next link and look for the Hydraulic Fluid Cross Reference Chart for hydraulic fuild brand reference:
Mar 04, 2011 | Simrad AP24 AUTOPILOT DISPLAY UNIT
Selenoid bypass valve has failed
Contact and he can help you.
May 07, 2010 | Simrad Ap1603r Autopilot Ap16 Rc36 Rf300...
Simrad AP 11 Autopilot control head
I happen to have an ap11 head unit in good condition, please contact me.
Oct 28, 2009 | Simrad Boating
Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
yes, hook it to 12V it runs, reverse wires it runs opposite it will spit oil, watch out! shoulda coulda left it in place and tested with jumper cables or battery if pump is bad 1 find out why your boat eats pumps 2. call me, i have it in stock for less than you paid before (most likely) 3. you can replace the electric motor without disturbing the hydraulics!!!
Sep 13, 2009 | Simrad Rpu160 Reversible Pump 21118237
GPS/Fishfinder keeps dropping and restarting
Do a software upgrade to the CE33 unit and then a master reset by unplugging the power cable , then press and hold PWR and CLR buttoms while plugging back the power cable. Wait a couple of second while the software reloads and should run smooth....
NOTICE: All the previous data as routes, waypoints, etc that you had will be lost by the master reset.
Jan 27, 2009 | Simrad Ap1601r Elect Only Ap16 Rc36 Rf300...
Simrad Ac10 Course Computer Logo
445 people viewed this question
Top Simrad Boating Experts
Michael Vincent Cruz
ray gallant
Are you a Simrad Boating Expert? Answer questions, earn points and help others
