Question about Honeywell Programmable Thermostat Heater
Require room thermostat for ferroli combi boiler optimax 25c . I have a honeywell at the moment which stopped working. it has two wires coming into it from the boiler
Get a Ferroli wireless programmable room stat. City plumbing supplies can get hold of them but you'd be looking at approx £130. Part number 30800009. No wiring involved, the receiver connects to the boiler pcb. Had same problem but now fine.
Posted on Mar 12, 2009
  • 333 Answers
Almost any thermostat you install will have the 2 wires that you are looking at It depends on how in depth you want to get with your thermostat. Home depot will have what you need. I hope this helps. Don't forget to rate my answer.
Posted on Feb 18, 2009
Ferroli boiler optimax he 38 c.Powers up ok,no hot water,no error code.Think its an ignition problem.Heating flame not showing?????
Is there an error code? If not the flow sensor for the hot water could be faulty. Also if you've had a power cut depending which model of Optimax HE you have, you sometimes have to tell the boiler it's a Combi, as they have a generic Pcb fitted which is also used on the system only boilers.
Sep 26, 2013 | HQRP Universal A/C Remote Control...
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
Fault code f26 ferroli optimax 25c how to reset
There is a parameter on the pcb to change would take 30seconds to do. Never replace ur pcb for these faults. Hold down reset untill u see t5 press reset 1 more time it will then say p01 press the heating temp button until u see p02 press the hot water temp button until it changes to numberv2 and that will fix ur problem
Dec 25, 2010 | Heating & Cooling
Fault code ( nocn ) on a ferroli boiler
if nocn is on the time clock then check the wiring to time clock and if all good then it is the time clock at fault and will need repleacing
Apr 25, 2010 | Heating & Cooling
Optimax 25c ferroli, central heating!!!!!!!!!!!help!!!!!
there should be a perm on setting on the system so instead of running it on timed mode switch it to on there is also a boost wich usually give 1 hour of heating
Mar 21, 2009 | Honeywell Programmable Thermostat Heater
Ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
1,565 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
