Question about GE 24 in. GSD2000Z Built-in Dishwasher
I have a GE Potscrubber dishwasher that only hums, won't run
I have a GE Potscrubber dishwasher that I rarely use, but when I tried to use it recently, it just hummed but nothing else happened. When I tried to manually move the dial, water started to come in just past the Rinse and Hold setting but it would not pump the water out.
  • kolbur2006 Mar 28, 2009
    This happened to me several years ago on my 1 year old potscrubber dishwasher that was installed in my new house. It was just outside the warranty, so I had to pay. The repairman said it needed a new motor. So for $250 I replaced it. 5 years later, it did the same thing. Threw the thing out. No more cheapy potscrubber dishwashers for me!
I have a portable that had the same problem. I called a repairman and he turned a fan blade on the motor. Mine is located on the right side about 12" in. It gets hung up when it is run often enough. If your problem is the same is mine all you have to do is turn the blade and it works like a charm. Hope this helps.
Posted on Feb 28, 2009
  • Connie Michelich Feb 28, 2009
    That should is not run often enough.
  • 423 Answers
SOURCE: LG LDF6920ST Dishwasher won't start
With nothing displaying and only the humming sound, it appears that the main controller card (PCB) has most likely failed.
If it were my dishwasher, I would add a pitcher of water (more than two big glasses full), close the door and start a cycle and listen at the drain. The first thing a dishwasher does is run the pump to empty any standing water before it fills up. If you hear that water drain, (and can see that is has drained from inside the dishwasher) it is not as broken as I think it is.
BUT, this dishwasher should be displaying something from the moment you press the power button.
Please post back with what you find and decide you do. OK?
Posted on Apr 18, 2009
  • 423 Answers
SOURCE: My dishwasher is making a humming sound and does not rinse?
A humming sound can be a failing wash motor (that drives the water pump) or it can be as simple as a blockage in the the pump area beneath the lower spray arm, under the filter.
Remove the spray arm and the filter top (screws will need to be removed)
Use a flashlight and inspect all over the sump area for debris that is blocking/jamming the impeller area. Reasemble and test with a short cycle.
If the dishwasher continues to make the same humming, it is time to replace the wash pump.
Good Luck! Post back here if you would like more guidance.
Posted on Apr 11, 2009
  • 1073 Answers
SOURCE: Dishwasher hums loudly while running
if this hum is in the wash cycle then dissasemble the top of the pump assy and look for foreign objects in the pump
Posted on Apr 22, 2008
SOURCE: GE POTSCRUBBER 1200 DISHWASHER
Hi. My GE Potscrubber 1200, Model GSD120055, stops mid-cycle and does not drain the water. It stops on Rinse and Hold.
I can nudge the dial and the dishwasher completes its cycle, so the drain and pump are okay. Is the problem with the timer or something else ? Please help, O Wizards of Washing.
Posted on Mar 27, 2010
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
Ge potscrubber 940 dishwasher
My GE potscrubber, model GSH942 (very old) is not working, as one of its part was fumed (burned). Though the dishwasher is old, it was doing perfect job. Kindly advise whether there is any hope to save it. picture of damaged part is attached.
664ecbc5-d293-4bf8-9a26-d4eb60b56c88.jpg 3afc25c1-d149-45c7-8546-1d01d256fcd6.jpg 2ffcde17-d805-44d2-865f-843483703dd0.jpg
Aug 10, 2013 | Dishwashers
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
Looking for dishwasher manual for Model Number GSC700X01AD. GE Potscrubber 700
is this the manual your looking for http://www.managemylife.com/mmh/owner_manuals/4241/GE-Dishwasher-L0801045?brand_name_search=GSC700X01AD+GE+Potscrubber+700+ if you have any further questions or feel that this is not the right manual message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to help others in similar situations in the future Thanks Rick
Feb 13, 2011 | Dishwashers
Ge potscrubber 650 Dishwasher is humming when turned on and will fill but not wash and drain
This happens when the DW goes unused for a while. The motor is stuck. Open up the lower panels and move the Motor Fan by hand until it moves freely. This worked for me until a seal broke.
Freeing the motor may break the seal between the motor and pump assembly. I'm in the process of replacing that now.
Check for leaks by running the DW before putting the lower panels back on.
Aug 14, 2010 | Dishwashers
Hello, my 1992 GE potscrubber 630 is not cleaning well at the moment. Could vinegar or a little bleach help if it something is clogged with hardwater or food particles. thx.
My GE Potscrubber 630 dishwasher leaves a white film on all of the dishes. Is there a filter that can be cleaned out?
Aug 07, 2010 | GE Dishwashers
GE Potscrubber will not drain or cycle.
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 13, 2010 | Dishwashers
My GE Potscrubber Dishwasher doesn't spray water when it is turned on. It has power.
If you turn it on and hear a slight hum after water fill the motor is locked from non use. You will need to remove bottom panel and with power off you will see the motor right in the middle near the front. This is called a side winder motor because of how it sits. There are some blades you can turn to unlock the motor. Once the motor breaks loose which you will be able to tell when it does, turn power back on and let run thru complete cycle with heat dry in the off position. GE are about the only ones out there that will do this and it is usually from lack of use. Hope this helps.
Feb 21, 2010 | GE Dishwashers
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
GE potscrubber 700
upc leaks when dishwasher is emptying
May 12, 2008 | GE Dishwashers
GE 24 in. GSD2000Z Built-in Dishwasher Logo
2,377 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
