Question about PPI DCX-500.2 Car Audio Amplifier
I got a 500.2 dcx precision power amp, at first it bumped but lately it bumps but turns off (well not off it says clip out/ termal protect). I have to mess around with the power and ground outlet and then it bumbs but does the same thing agin.what could it be, is it the amp or the battery,or do I just need to buy new power and ground imputs?
  • 113 Answers
You might need to just solder them better
Posted on Jul 05, 2009
SOURCE:
Tail lights not working
Not for tail lights.
GeT a 12 Volt probe screwdriver with the handle that lights up or volt meter. Remove the bulb turn on tail lights clip to any good ground and put the probe tip on the bump at the bottom of the socket and it should lite up. Now clip ground to side wall of socket and probe both bumps in the center one bump is tail the other is brake. Have someone push on brakes and see if they light when on one bump then check tail on other bump. DO NOT TOUCH THE SIDE WITH CENTER PROB OR IT WILL SHORT BE CAREFUL. this will tell you where the problem is,
Also check fuse holder.
leave fuse in clip to ground turn on tail light and probe both ends of fuse for power.
Hope this helps Mike
Mar 03, 2016 | Cars & Trucks
Bump on carriage
We would need a bit more information.
Where and when does the bump occur?
Apr 18, 2013 | HP DesignJet 500 InkJet Printer
I just got my PPI dcx 300.2 amp back and i hooked it all up, and connected the fuse back in and started the truck, the amp turns on but the red light starts blinking and says clip out. The amp doesnt smell...
Are you sure everything is correctly connected. If you are running the amplifier in bridge mode then take note that the load to the amplifier can be no lower than 4OHM. dreamsystems
Feb 25, 2011 | PPI DCX-300.2 Car Audio Amplifier
Bumps good but every 10-15 min of bumping it
to much power hooked up to it take something away
Jul 21, 2010 | AudioBahn A8002T Car Audio Amplifier
My amp keeps going off on protection mode as soon as the bass starts bumping
check powers and earth, unplug sub and crank it up see if it still goes into protect if it doesnt the sub is too much load for that amp and could have damaged the amp, if it still does it then its a fault in the amp or power problem make sure you have good thickness 4gauge and good earth
Apr 26, 2010 | Legacy Audio American Legacy II LA290 Car...
No sound but still has power
Yes, one bad speaker connection can cause the radio to shut off all output in a type of protection mode to protect the rest of the speakers...if not that, if the vehicle is equipped with an amp, make sure the amp turn on wire is well connected.
Oct 23, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
The protection light keeps coming on
That means something isn't wired right. Make sure that all of the power inputs from the battery are correct. Most importantly make sure no bare wires are touching (IE the positive and negative bare wires going to the subwoofer terminal.) If it keeps persisting, check the voltage level in the car and make sure it is normal, because some fancy amps have protection where it will go into protect mode if the amplifier is not getting enough power to supply. Also, does this happen when you are really bumping (like high volume) or just the second its on it cuts? Because when you really play it loud and it cuts, sometimes you are putting too much a load on the amp. Make sure the fuse in the amplifier is the correct fuse for the amplifier.
Oct 13, 2009 | Jl Audio 500/1 Car Audio Amplifier
Ppi dcx 1500.1 is it 2 powerful 4 da 12in. L7?
Hello montyski20,
The amp outputs 500 watts RMS into 4ohms, 750 watts RMS into 2ohms and 1000 RMS into 1ohm.
The L7 can handle 750 watts RMS (375 watts per each coil). If your L7 is the 2ohm version, you should wire the voice coils in series, the positive marked coil to the negative unmarked coil. Then connect the remaining positive and negative to the amp terminals. This gives you a 4ohm load (500 watts). If your L7 is the 4ohm version, wire the voice coils in parallel, both marked and unmarked positives together, likewise both negatives and then to the amp terminals. This gives a 2ohm load (750 watts).
Paralleling the 2ohm sub will result in a 1ohm load (1000 watts) and that is too much for the L7.
Hope this helps.
Aug 02, 2009 | PPI DCX-1500.1 Car Audio Amplifier
Mine has done the same thing. except its says "clip out"
sounds like it may be a power supply problem in the amp. If it was slowly getting worse, you may suspect a capacitor in the power supply to have failed, or popped. Open the amp, and look for any swollen tops of large capacitors around the big donut shaped coils. If any of their tops are swollen or bulged out, that's your problem.
Jun 12, 2009 | PPI DCX-500.2 Car Audio Amplifier
Protection mode
Disconnect all speaker wires from the speaker terminals of the amp. If it powers up and doesn't go into protect when you increase the settings, the wiring needs to be checked. If it still shuts down, the amp may need to be repaired.
Does it shut down or make loud noises when you move the RCA cables where they plug into the amplifier?
Mar 27, 2008 | Power Acoustik LT-980/2 Car Audio...
PPI DCX-500.2 Car Audio Amplifier Logo
265 people viewed this question
Top PPI Car Audio & Video Experts
Mike Duncan
Mike Duncan
Anthony Ward
Anthony Ward
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
