My Phillips 8P5434 C101 TV's picture started closing in from top to bottom like bouncing then made a pop and went dead. T V repairman came out and said it needed 3 parts and that one of the parts was no longer avaiable. PN#483520988561 PN#483520987712 he made it sound like I needed 2 of one of these which is the one no longer availble and one of the other which he says he has in stock. Need help here please Jerome
  • 1 more comment
  • jrome101 Feb 18, 2009
    He didn't say what they were, but after trying to find the parts myself, they seem to be a ic opt something?
    How many of each and can I replace them, found where 1 of each are locatd but curious where and which one is the third?
    Thank you and yes I got the info I needed,
    Jerome
    Brigadier General:
  • 3,614 Answers
for clarification, what did the repairman say what the specific name of that parts
Posted on Feb 18, 2009
  • 2 more comments
  • micromaster
    micromaster Feb 18, 2009
    go HERE
  • micromaster
    ok. i got it.
    it both IC.
    you can purchased the items HERE & HERE.
    hope this initial info helps you..
    for further assistance, let me know.
    also; kindly please put a rating on my solution here.
    Tnx.
    micro
  • micromaster
    its probably on the power supply area. use a multimeter to test each IC on the powerboard.
  • micromaster
    also. this IC can be located on the converge module.
Sound went out. Heard a
if you using non-integrated speakers check the cable if integrated call a repairman dont open your TV yourself it's dangerous
May 28, 2012 | Televison & Video
Phillips magnavox big screen rear projection tv
Base from the description that you gave us this is really a symptoms of a bulb that is going bad and needs replacement already, because it will just go bad dark as time goes on so it will be better for you to have the bulb replace as of now ....
Good luck.........
Aug 17, 2008 | Televison & Video
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
My phillips 42 inch lcd tv just went pop / bang and the picture disappeared - its now dead with no light - checked and replaced fuse
The power supply board is dead.That the board,where the power a/c cord plug in to it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 14, 2010 | Philips 42PFL5332D 42 in. LCD Television
Picture went dead
More than likely your backlight inverter board went dead
May 30, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have a Philips Magnavox 51MP392H Rear Projection Television. The model #8P5434 C101 the serial # 13091835. While moving my television the screen for the front of the television flew out the back of my...
I might contact a local TV Service Shop, they usually keep ones that people don't wish to repair. They just might have a screen for you.
Blessings,
A/V Media Tech Guy.
Nov 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
How to open passenger side door panel
Difficult to describe without pictures & illustrations.
1. The door handle is two-piece and the top piece is pryed off/out with a small screwdriver (needs to be removed in order to access two phillips screws behind it.. one at the top and another at the bottom).
2. The door release handle (inside cover) also has a small square cover that needs to be removed to access another phillips head screw behind it... then the cover pops out.
3. Below the arm-rest, there are two more cosmetic plugs covering two more (larger) phillips head screws which must be removed as well
4. The tweeter speaker (forward upper corner of the door is also 'popped' out to allow lifting the panel out of the door frame.
5. Now, there are approx four (4) more screws which need to be removed (covered by cosmetic bottons) three (3) aft and one (1) (possibly 2) forward.
6. Finally, the door panel is held in place by several pop-in round clips. Start prying at the bottom of door panel to start popping them loose & work your way upward to the top of the door panel... once all pop-in clips are popped out, you can now LIFT on the panel to remove it from the door frame. -- careful with the wire harness & connectors inside the door panel & cavity.
Oct 03, 2009 | 2003 Hyundai Tiburon
TV wont power on but green light indicates power on
No,it ur backlihght video inverter board is dead,need a new board.
Sep 27, 2009 | Philips 50PFP5332D 50 in. Plasma...
Popping sound with picture
try getting a cleaning kit from radio shack for 15 bux the lens maybe dirty
Jan 21, 2009 | Haier TN201AUV 20" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
