Question about Dell Inspiron 1501 Notebook
Can turn computer off and on and I will see the windows screen then the screen goes blue with a blinking cursor. I also have a dell.
It is related to bios enabled computrace models. It has happened twice to my dell 1525 I bought it 12/08. The software used to image your recovery partition is incompatible with the two tiny hidden partitions computrace uses. Computrace gets corrupted and shuts you down like you stole the laptop through no fault of your own. All of you data is still there so don't worry. can turn computer off and on and I will see the - smile.gif
According to dell, you have to remove the hard drive, download your correct bios from their site using another computer of course, and while the hardrive is still removed, flash the new bios and then reinstall the hardrive and it should work fine with all your data intact.
I found this tech update at dell's website this problem goes back to 2005 but the most recent update was dec. 2008 and includes many laptops including the 1500 series.
Computrace freaked out and completely disabled your system. You can send it back or follow the instructions in the update if you are out of warranty.
I am a graphic designer so I needed to finish a project, so I did this to get it running again, backed up my data, and sent my laptop back for a replacement.
I have included part of the update and the Dell web link for you below.
Certain Dell™ Portable Systems Display a Black Screen with a Flashing Cursor when Booting from the Hard Drive
This issue only occurs on Dell portable systems that shipped after Oct. 31, 2005, and have the following configuration:
  • The CompuTrace BIOS feature is supported and has been set to Activate.
  • A system account has been created, and the laptop is registered with Absolute Software.
  • The Altiris Backup and Restore application for local client has been installed.
Affected systems manifest the following symptoms:
  • When the system is powered on, it does not complete the boot process, and the only indication that a problem has occurred is a black screen with a flashing cursor in the upper left corner of the display.
  • The system cannot boot from any media as long as the hard drive is attached. The only way to boot to other media is to remove the hard drive from the system.
Altiris Backup and Recovery software uses an atypical mechanism to hide a partition within the system volume. This mechanism involves hiding valid data relating to the Altiris Backup and Recovery software in marked blocks that the operating system is designed to ignore. The installation process for Altiris also leaves table entries that store directory information for NTFS. These entries are formatted differently than those normally observed on an NTFS-formatted partition. These changes were not anticipated, and we are not aware of any other product that uses the file system in such a manner.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=2A28448CB118EBAFE040A68F5B2854D5&doclang=en&cs=
I hope this helps.
Posted on Feb 19, 2009
Dell Dimension 2400 runnning windows XP will not boot up
there are several issues and there are several solutions for this problem. I need you to please be more specific. Usually when a computer doesn't boot up, it goes to the initial black screen and usually it will display a message by the top left of screen where cursor is blinking. Please tell me whet that says, and I will tell you exactly how to fix the problem.
May 20, 2014 | Dell Computers & Internet
I have a inspiron N5040 with windows 7 When I turn on it goes to windows recovery screen. I followed the repair(recommened) it will eventually bring up a blue screen with a cursor but no way to log in. I...
Try installing on top of its self. It may create another directory and rename the original Window (old). This however will cause you to lose your settings like installed apps and documents. They will be in the OLD folder, but not readily accessible on the new install.
Jun 10, 2013 | Dell Inspiron N5040 Black New
Cursor and text jumps for dell inspiron 1150
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens. Type "Cursor blink" in the "Search programs and file" text box. A list opens. Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens. Click the "Speed" tab. A list of options appears. The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast." Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale. Click "Apply." Click "OK." The cursor stops flickering on the screen.
Feb 04, 2013 | Dell Inspiron Computers & Internet
My laptop will not turn on. It begins to start normally with the Windows screen, but goes black with just the cursor showing, then goes into a kind of sleep mode with the cursor grayed out. When I plug...
Put the Windows disk in and repair the drivers. Should be easy follow on screen instructions, if not use the DELL OEM disk to start and do repair. I have a Dell Inspirion it did this b/c of a virus. I just did a repair WIN7 and all is good now.
Jul 10, 2011 | Dell Studio 17 Laptop
When we turn our dell computer on, the Dell logo comes on, then the monitor goes black with cursor blinking in the upper left hand corner.
Start the computer hand hold down F8. Then you have a menu where you can chose to start windows in safe mode. If you can get in, check your log files to see what the problem is.
Jan 23, 2011 | Computers & Internet
When starting up I keep getting a black computer screen with blinking cursor
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd.
Dec 14, 2010 | Dell Optiplex 755 Desktop Desktop Computer...
Black screen with blinking cursor upon start up
You don't say what Windows are you using.
Anyways, it seems like you have a corrupted BOOT problem.
On Windows Vista and Windows 7, you can insert your Windows installation CD, and choose the "Repair my pc" option.
Windows will do it automatically fro you, and you'll be up and running in a couple of minutes.
Dont forget to rate this answer if it helps.
Jul 18, 2010 | Dell Inspiron 531s Desktop Computer
Startup screen goes black except for the cursor
Get a new OS Installer, I suggest you take Windows 7
Oct 18, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 1501 Notebook Logo
267 people viewed this question
Alun Cox
