Question about Amana 3.2 cu. ft. Top-Load Washer
Maytag leaks water in the spining cycle and makes a loud noice.
I am confused if it is the tub seal or the water pump. Started leaking just a little water and know is leaking much more.
    Problem Solver:
  • 20 Answers
How old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
Posted on Feb 18, 2009
Spins slow, does not drain and leaks a little.
SOUNDS LIKE MIGHT BE SEAL LEAKING WILL NEED TO DO BEIRINGS AND SEALS
Jun 17, 2012 | Maytag LAT2300 Top Load Washer
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Water leaks from under during spin cycle
There are multiple reasons why your washer would leak during the spin cycle. The wash tub seal could leaking, The tub bearing could be leaking, The carbon seal on the top of the tub boot could be worn. The water injector tube where it connects to the top of the tub could be torn from age. Even the tub to pump hose could have a hole in it. These are the most likely causes. There is one more item being the stem seal could be shot but this would cause water to leak all of the time.
Jan 06, 2010 | Maytag Washing Machines
Leaking washer
This is going to be the tub seal. Take the front off and check to see if the water is leaking right where the tub and the transmission meet and if so the seal is leaking. This also makes the washer noisy. This page should help http://appliance-repair-it.com/Maytag-tub-seal.html
Sep 15, 2009 | Maytag LAT3600A Top Load Washer
Loud spin cycle - leaks water
No boot on a top loader, the tub seal and bearing are gone, water leaked from the tub seal, rusted the bearing and quite possibly the milk stool and transmission. Check your warranty, the transmission may have a 5 year limited warranty, usually it will include the tub seal and bearing with the kit.
Jun 13, 2009 | Maytag Atlantis MAV9501E Top Load Washer
Maytag Atlantis Top Load MAV6250AWW Drum Leak?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Oct 22, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Amana dlw330ra, loud and leaking
HI,
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Aug 11, 2008 | Amana DLW330RA Top Load Washer
Water leaks and spin cycle not working properly
Water leaking from the bottom usually indicates either a bad hose , bad hose connection to the pump or a leaking pump. Also sounds like the machine is not spinning out. Is there water left in the tub at the end of the cycle?
Feb 28, 2008 | Maytag MAV7600 Top Load Washer
Maytag washer
dsands, if the noise is like a train roaring then it could be the bearing. The fact that you have some water leaking leads me to believe that the tub seal leaked onto the bearing. Now this could be covered under the 5 year warranty, depending on the tech that comes out. Another possiblility is that something is caught in the pump and it is leaking. You would have to open the front panel to get a look. On these Maytags if something gets in that pump like a button etc., they will scream like a raped ape. With out being there my gut feeling tells me the seals leaking and ruined the bearing. Catriver.
Dec 15, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Amana 3.2 cu. ft. Top-Load Washer Logo
252 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
