Question about Sharp AL-1551CS Printer
H4 for Sharp Copier AL1551 CS
H4 flashing on my Sharp Copier AL1551 CS
  • 95 Answers
The H4 code indicates the system did not or is not warming up. It could be a thermostat or thermistor or a board problem or a heating lamp issue.
It requires service.
Check the fuser unit for any debris or excessive build up especially around the thermistors - if you can remove and open up the fuser unit !
Posted on Mar 21, 2009
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
Tip
Sharp AL Series Copier H4 H-4 service code reset
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Jan 04, 2010 | Office Equipment & Supplies
My copier is flashing the code H4
I have a tip posted here on Fixya that resolves this problem easily.
Here is the link:
http://www.fixya.com/support/r4376849-sharp_al_series_copier_h3_h_3_code_reset
If it works for you then please return here and provide feedback for me that I was helpful.
Thanks
Jul 25, 2010 | Sharp AL 1631 Copier
Sharp AR-123E, H4 error code, printer not ready
it doesn`t need to change board. code 14 clears.
May 04, 2010 | Sharp AR-M205 Copier
Copier flashing "H4" code
Hello sir;Follow these steps within 4 seconds; press 'clear', "exposure" ,"clear" "exposure" then enter 14 hit print, should be OK.
Jan 30, 2010 | Sharp AL 1631 Copier
H4 code flashing. turned it off and back on...still flashing. anything else we could try?
See my tips and tricks solution for this problem on this site. Just search for Sharp AL series H4
Jan 25, 2010 | Sharp AL 1631 Copier
SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Nov 01, 2008 | Office Equipment & Supplies
Sharp AL-1551CS Printer Logo
354 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
