Question about Canon PIXMA MX310 All-In-One Printer
What cords go where to recieve faxes
I want to receieve faxes what cords go where? where does the phone cord and the line cords go?
  • 385 Answers
Line cords go in at the L and phone by the one with the picture of the phone!Hope i helped!
Posted on Apr 01, 2010
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
How to work my fax
Plug the phone cord into LINE and then directly to the phone jack in the wall.
setup recieve mode by pressing the MODE button until it is on the mode you want.
Mar 28, 2010 | Brother IntelliFAX 565 Plain Paper Film...
Hi my machine wont send or recieve a fax despite being properly connected. printing from computer is fine. has worked fine up until today
Hi check the following article to from HP
Problems with sending and receiving FAX
HP FAX ISSUES
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 05, 2010 | HP Photosmart 2610 All-In-One InkJet...
Won't fax or recieve faxes
Make sure your phone cord is connected to the LINE port of the fax machine.
Nov 25, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
My fax machine will not recieve or send faxes
Plug a regular phone into the wall jack, check for dial tone.
Make sure the phone cord is plugged into LINE port on fax machine.
Sep 16, 2008 | Office Equipment & Supplies
I have a MCF LC-51 series fax, and scanner I cannot fax or recieve.
check for a dial tone using a regular phone plugged into the wall jack.
make sure the phone cord is hooked into the LINE jack on the machine
make you do NOT have a DSL line.
Sep 02, 2008 | Brother Office Equipment & Supplies
How do i install the equipment
Plug in the power cord
Plug the phone cord into the LINE port of the fax.
It should be set to AUTO RECEIVE out of the box.
Jun 24, 2008 | Brother IntelliFax-2480C Fax
Fax not sending
It sounds like you have a problem with your phone line. If your machine has a reciever, pick it up or press the hook key. You want to listen to the dial tone. If there is any static in the line it will cause faxc problems. Also you can try disconnecting the fax and plugging in a standard phone into the wall jack. Make a phone call and aee if the line is clear or if there is static. If you do hear static in the line, first try replacing the phone line cord, from the wall to the fax, or phone. If that doesnt help then it is definatly a problem with the line and you must call the phone co. If the line is clear with the standard phone, and static with the fax reciever, or hook mode, then you may have a bad modem board in the fax. Let me know if I can be of further help! John
Sep 05, 2007 | Brother IntelliFAX 2800 Laser Fax
Cannot recieve any faxes on my canon L500 FAX
Can you send? Can you make copies? Do you have it set to auto receive?Is the phone cord plugged into the line socket? Let me know!
Aug 14, 2007 | Canon FAX-L800 Plain Paper Laser
Canon PIXMA MX310 All-In-One Printer Logo
35 people viewed this question
old marine
old marine
Corne Viljoen
