Question about RCA P52926 52" Rear Projection Television
52RCA have a 52RCA Projection when i try to turn on the set get popping sound like a circut breaker kicking, no picture or sound at all
  • signman920 Feb 18, 2009
    Thanks, It also before it started the popping sound the TV would sound like it was frying bacon, but I still had a picture and sound. I let it play all day and it quit working, it was then when i tried to turn it on it would make a popping sound and do nothing
  • Horrible TV Mar 06, 2009
    My tv is doing the same thing. It made this horrible sound like a VCR was rewinding super loud, and then it suddenly went blank. Each time I try to turn it on, all I hear is a clicking sound. Can you offer any wisdom of how to fix this?
    Sergeant:
  • 280 Answers
This is probably the High voltage splitter arching.
Pretty cheap part from Matt electronics
part# 205064 --- $22.50.. Look and see if you find any oily substance leaking down on the yoaks.. If you do you have a bigger problem
Posted on Feb 18, 2009
The A/c and heating unit does not cut on anymore. What could the problem be?
Are you sure you have power? Is it 220? if so double check Circut breaker. If it's popped and pops again when you reset, unplug the unit. Try to reset again, If it pops again when you reset, you have major electrical problem call electrician. If it holds, then you have a major appliance problem that is causing the unit to "pop" the circut breaker. If it's a central unit similar diagnostics, but you can't unplug it. So call your Heating service people. It may just be your thermostat if central system, or more.if the Circut Breaker pops.
Mar 06, 2015 | Heating & Cooling
Hln617w1x/xaa keep shutdown in 5 to 10 minute,picture kind of bleeding??
Its a common problem. The lamp needs to be replaced.
Call 1-800-samsung & choose the parts dept.
For the replacement lamp it cost $149.99 plus tax & shipping .
You give them the lamp code ( red sticker on the side of the tv) , they send it out 5day shipment.
Local tv repair services can install it for an installation fee. This will save money apposed to ordering through a tv repair shop who charges an order part fee plus etc...
Oct 17, 2008 | Samsung HLN617W 61" Rear Projection HDTV
14 in. saw with leeson motor
To start with what size circut are you trying to run the saw on? What ever the amperage is on the saw will draw almost 3 Xs the amperage rating of the saw on start up. If the circut is a 20 amp the breaker should hold long enough to start the saw. Also the saw should be the only thing running on the circut at the time. A 1-1/2 hp motor is a good size one aproximately 15.2 amps If you circut breaker is twenty amps and you still pop the breaker you may want to convert the motor to run on 220 volts as that will drop the load to approx. 7.6 amps Youcan run the saw on a 20 amp. 220 volt circut with no problem unless there is a problem with the motor. If the outlet is the only outlet on the circut it is an easy change to convert the circut.
Mar 02, 2013 | Target Portable Masonry Saw PS1411S...
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
Jan 07, 2013 | Goodman Manufacturing Goodman HKR-10C 10kW...
My d52w14 wont turn on at all anymore it got unplugged from the wall and when i plugged it back in there was a pop and i saw the electricity between the socket and the tv. the green light doesnt come on...
you have shortcircutted a fuse either on the plug or internally
its a quick and cheap fix should be less than £50
unless you have damaged some other stuff in it but you shouldnt have unless it was faulty and the fuse wasnt working properly
it works like the circut breakers in your house but the fuse needs to be changed everytime it is activated
Sep 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
IR T 20 air compressor will not kick on
IS IT THREE PHASE OR SINGLE PHASE? MOTOR TAG WILL SAY PH 1 OR PH 3.DOUBLE BREAKER OR TRIPLE BREAKER WILL ALSO TELL. IS THIS A BRAND NEW INSTALL OR AN EXISTING COMPRESSOR THAT JUST NOW STARTED DOING THIS. SOUNDS LIKE A POWER PROBLEM LIKE A MISSING PHASE OR BLOWN FUSE. REMOVE FUSES WHEN OHM CHECKING - DONT TEST THEM WHILE STILL INSTALLED.
Mar 14, 2009 | Air Tools & Compressors
No picture no sound
There are lights on the board about 8 you should look at which comes on and which stay on this by hitachi standards tells you what is wrong. Most of the time its convergence amps bad.
Sep 14, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
73 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
