Question about Akai CFTD2011 20 in. EDTV-Ready LCD Television
I have a CFTD2011 Akai TV. My DVD's won't play anymore. Whenever I press play it says pre stop or invalid key and won't play the movie. What can I do to fix this problem.
5 Suggested Answers
premtech
  • 934 Answers
SOURCE: Akai CFTD2011
You need to repair the SMPS - - common problem! Open the back and locate the SMPS (Power Supply) On it you'll find a series of electrolytic caps with position numbers. Replace C31 (1000 25v), C32,35 both (1000 Uf 25v) and C33 (680 Uf 25) and you should be good as new...
Bill
Posted on Feb 03, 2008
  • 148 Answers
SOURCE: flashing red lite..black screen
You have a defective power supply or another of the the processing board ... depends on the number of flashes ... please take to agent for complete diagnosis and repair
Posted on May 12, 2009
SOURCE: no owners manual for akai
I have one downloaded on my laptop and can email it to you. I don't want to display my email on this thread though. Any ideas how to communicate without displaying our info publicly?
Posted on Jun 05, 2009
  • 8457 Answers
SOURCE: completely dead
Power supply board is dead. Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Mar 06, 2010
SOURCE: Input buttons on a Akai cftd2011 Remote
Hi. If your Harmony remote has those discrete input commands, then you can test them out to see which input they all go to.
1. Update your remote (with the TV added as a device)
2. Press 'Devices' and select the TV
2. Go through all of the commands until you find any with the word 'Input' in the name, and test them. You might want to write down what inputs each of the commands goes to on the TV.
3. In the software, click 'Settings' next to the icon for your TV, and select 'Adjust inputs'.
4. Select method 2 (one button for each input), adjust the input list if you need to, and set the commands that you tested to the appropriate inuputs.
5. Update the remote and test your Activities.
Hope that helps you get yout Harmony setup!!
Posted on Mar 13, 2010
Run the signal from a AKIA DVD Lcd TV to a Projector Screen TV
from the back of the tv player it will connect to the projector on the big screen usig rca leads
Jul 30, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
DVD video showing without DVD in
have you tried pressing the dvd button twice on the remote?
Apr 13, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Mar 13, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Dvd player won't work
Its because the DVD tray is on the side of the TV and it was not build with enough vents, so when the DVD player heats up it case the DVD not to play... 1. Connect vendor or company and ask for a tech to fix it or replace it. 2. Try to replace the DVD player unit yourself.. 3. buy a dvd player... Note: it is always a good idea but the vendors tend to used not top quality DVD players in the combo units.
Jun 21, 2009 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Akai tv remote control
Go to Tigerdirect.com order Logitech Harmony 520 universal remote it is compatible with your AKAI CFTD2011 same as mine. Phone number is 800-800-8300. I also called logitech that makes this remote and it is compatible..........finally a remote that works.............
Mar 11, 2009 | Akai CFTD2011 20 in. EDTV-Ready LCD...
DVD Player Problems
YES-- Not a well built TV in my opinion! And the cheap DVD play table and pick-up assemblies are of no better quality that Colby..
Bill
Jan 20, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Only two channels
need to scan for chs in menu of the tv and add hd antenna if u havent yet maby better one like non powered
Jan 03, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Power supply "Starmen TOD0851212" for my AKAI 20
If you can do it yourself replace C31 (1000 25v) also good idea to replace C32,35 also (1000 uf 25v). Theres also C33 (680 uf 25) if you want to replace it.
Dec 01, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Borken remote; universal remote doesn't work!
I have had on order since December 2007 the Akai replacement remote #WIR3500001-EQ01 the Akai TV/DVD combo model #CFTD2011. I called each month for 5 months, being told each time that it was on backorder. A few days ago, I received a letter in the mail stating that this remote is no longer made and is not available.
I too have tried universal remotes without any luck. If anyone has a resolution, it would be greatly appreciated.
Nov 19, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Akai CFTD2011 20 in. EDTV-Ready LCD Television Logo
41 people viewed this question
Top Akai Televison & Video Experts
Dave Naylor
Dave Naylor
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
