Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
I start my sporty every few weeks in the winter just to make sure all is well with the bike, but the last time i started the bike i let it idle for a while and get good and warm i shut it off so that i could cover it back up, but for some reason i wanted to hear it run again so i flipped the key on and hit the start button and everything went dark , all the lights and no ignition. i dont know where to start looking for the problem, i never got a manual from the dealer. could someone help me with this problem?
  • 216 Answers
Start by checking the battery. Turning on yer bike and letting it idle is gonna drain the battery over time. Check the charge with a voltmeter. Should be at 12.5 Amps at least. If it is, I'd check the battery cables next for good tight clean connections ( if u dont have one - get a charger)
If that dont do it - get back with me - I got more
Posted on Feb 19, 2009
Reduced engine power warming came on yesterday, after driving in extreme cold temps, idled rough and the. started back up fine after sitting a few minutes. Drive today, in cold temps again, and drove...
Well...my ball park guess on this is just a tune up. The engine light is usually showing a misfire. If the plugs are bad then the cylinder is not igniting the fuel and it is flooding out. With what is here this makes sense to me. Let me know what it does turn out to be.
Jan 24, 2013 | Cars & Trucks
My 2001 mustang wont start in cold weather
sounds 2 things here. fuel pressure regulator or the idle air control valve. I an goingwith idle air control valve
Nov 12, 2012 | 2001 Ford Mustang
Bike started sputtering espeacially when cold after sitting thru the winter Would like to know how to change the fuel filter to see if thats the problem
Most likely the problem is not the fuel filter. Since the bike sat through the winter, it is probably fuel gummed ports/jets. This is happening more often especially with the ethanol blend of fuel. In the last few weeks, as riders bring their bikes out of winter storage, there has ben many with the same problem as yours. I recommend pouring at least 1/2 can of SeaFoam in the tank, lock down the front brake and rock the bike back and forth to mix the additive. Once it is mixed, crank the engine and run at high idle for a couple minutes. Let it set for an hour or so to give the SeaFoam time to work. Crank the bike, and ride normally. It should clear up. If it doesn't clear up in an hour or two, you may have water in the carb bowl that will have to be drained.
Apr 23, 2011 | 2005 Harley Davidson FLHR - FLHRI Road...
I can get my j1 to idle but when i open the throttle it stalls.the pistons in the carbs chatter (all 4) as soon as i open the throttle before it cuts out
Has the bike been setting up over winter or for a length of time over a couple weeks, with gas in the gas in the tank? If so, the ethanol additive to gas has caused the fuel to gum up and block carb jets and passages. My recommendation, if setting up is the case is to put a can of SeaFoam in the fuel tank, shake the bike back and forth to mix the fuel and SeaFoam. Start the bike and run at high idle for a few minutes. Shut it down and let set a couple hours and start and run at high idle again. Repeat this several times trying to accelerate. If it's a gum problem, it should clean itself up with one can of SeaFoam. If it doesn't, it could be an adjustment problem, or the carbs will need a manual cleaning.
Apr 12, 2011 | 2000 kawasaki ZX-6R Ninja
I have a 2005 with only 3000 miles on it. I could not start the bike and thought my original battery was weak. I had it on a trickle charger with a green light, but as soon as I tried to start the bike a...
As this point you can't get the bike to turn over is this correct? If the engine is turning over but won't start then yes the gas is most likely the problem. Gas after sitting for even a month can evaporate from the fuel system and it leave a fouls smelling deposit behind that clogs up everything. It stinks and it's a mess to clean out. To prevent this from happening use a product that is called "Fuel Stabilizer" in the last few tanks of gas before you put the bike away for the winter or a dormant period. If the motorcycle is in a hot climate or heated garage this foul smelling gas can happen within a few weeks.
Apr 10, 2011 | 2005 Yamaha Road Star Silverado
What kind of maintenance should i do to my 1989 cbr 600 f to keep it in tip top running condition
  • Change gearbox oil every 3000 miles. Change oil filter every 6000 miles. Use 10w40 motor oil. NEVER use synthetic lubricants as they can mess up the clutch.
  • Oil the chain every two weeks. Lube the control cables every oil filter change.
  • Keep the gas tank full in the cold months. This lessens internal tank rusting due to condensation in the tank. Drain the carbs when the bike will sit over the winter unless you plan on starting the bike every two weeks and letting it run for 15 minutes each time.
  • Be sure the gas valve is turned off when the bike is not in use.
  • Get a 2 amp trickle charger and charge the battery once a week for 4 hours in the winter. Be sure to keep enough water in the battery to cover the top of the plates in each cell. Know that batteries only last two years or so.
  • Check the chain tension once a month during the summer riding season.
  • Please rate my answer. Thanks.
Sep 11, 2010 | 1989 Honda CBR 600 F Hurricane
Help with getting Yamaha 1981 Special running after winter.
Drain the old gas out of the tank to start with. Remove the water trap bowl at the bottom of the petcock, (gas valve). Any water or trash in the bowl? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Be sure the bolts are tight. INSTALL AN IN-LINE FUEL FILTER. Let the float bowl fill then start the engine. Set the idle speed with the idle screw. This process should get you back on the road.
Please rate this solution. Thanks!
Apr 11, 2009 | 1981 Yamaha XS 400 Special
I cant start my motorcycle
Check the carb for old petrol, drain off by unscrewing the brass bolt at the bottom of the carb, and allow new petrol to flow through on the starter. Petrol 'goes off' in time!
DG
Dec 15, 2008 | 2008 Harley Davidson VRSCAW V-Rod
Charging problem
stopped for lunch back on bike it started fine. About 20km later I heard the engine revs on my speakers running autocom of the bike the speedometer started going mad jumping from 30km/h to 220km/m, all over the place. The last time this happened was in France and the bike did not start again, battery was flat, bike shipped back to Ireland. Back in Ireland the dealer kept it for few days, battery was fine just needed to be charged, could find no other problem with the bike. While this time I rode straight to the dealer, about 20km away. When I stopped the bike was dead, no power. They did a test and said the regulator is faulty. Was waiting for new one from Aprilia but it did not arrive today so they took one from a new bike. The bike is charging when reved but does not want to charge at idle so they need to go fishing for the fault. It now also seem my clocks are broken as a result of al of this. ,Check to make sure that all of the chassis grounds are free of corrosion and properly connected. I have never had an issue with charging at temperatures ranging from below zero into the mid/high thirties (Celcius). Even at low speed you will be turning 3000-4000 RPM which should have the charging voltage between 14-14.5 V. Put a multi meter on it and see what voltages you are getting at different RPM's,,,
Nov 10, 2008 | 2005 Hartford Legion HD-150L
Charging problems
Nov 10, 2008 | 2006 Aprilia Leonardo 300
Lands Phones Logo
75 people viewed this question
Top Harley Davidson Lands Phones Experts
David Payne
David Payne
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
