Question about HP Designjet 5000 Printer
Replace HP designjet carriage 5000 belt - HP Designjet 5000 Printer
  • 37 Answers
You need some skill and expertise, if you have, download the service manual
http://www.eserviceinfo.com/equipment_mfg/HP_22.html
Posted on Aug 28, 2009
713printech
  • 32 Answers
SOURCE: Replacement carriage belt for HP DesignJet 800
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
Posted on Nov 19, 2008
  • 8 Answers
SOURCE: Replacement carriage belt for HP DesignJet 800 Printer
It is not recommended that the user replace the carriage belt, on any HP printer. Any damage caused by the user, won't be covered by the warranty and will likely result in a completely useless, but very expensive doorstop. Or paperweight..
I do believe your printer has since been discontinued for support, however only an HP Customer Service Representative would be able to confirm that. I would suggest phoning HP for technical support or to at least confirm whether support is available.
Even if your printer is no longer a) under warranty, which I suspect it's not, or b) out of support completely, they may be able to provide you with a list of Authorized Service Providers (ASPs) within your area.
1-800-474-6836
Best Of Luck.
Posted on Dec 15, 2008
  • 8 Answers
SOURCE: carriage belt fitting
1-800-474-6836
Best Of Luck.
  • 123 Answers
SOURCE: carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Posted on Apr 15, 2010
  • 38 Answers
SOURCE: need instructions to replace carriage belt for hp
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Posted on Jul 12, 2010
Hp designjet 1050c check printhead path (1) but the carriage barely moves?
Either the belt pulley is broken, or installed incorrectly, or the belt was installed backwards.
Dec 26, 2012 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 500 carriage assembly it's vibrating
Get carriage assembly out from the service station area, remove right door, check right side pulley of carriage belt, weather its cracked or dirt particles deposited on it, clean/replace it, lubricate carriage rail, fix back every thing check .. best of luck.
Nov 26, 2012 | HP DesignJet 500 InkJet Printer
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
I have problem with my 5500 hp: check printhead path 2
The most common cause of the Check Print Head Path Error 2 is a worn out carriage belt. Open the top cover and locate the carriage belt. It is the long thin belt that extends the full length of the plotter. Use a light and look under the belt for debris that looks like pencil erasure crumbs. If the crumbs are there, the belt is disintegrating and needs to be replaced. See: http://www.lpscomputer.com/c-732-designjet-5000-5500-belt.aspx
Dec 01, 2010 | HP Designjet 5500 (42 in.) InkJet Printer
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
Carriage belt replacement
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
I don't know where to buy carriage belt
http://www.computercare.cc/osc/catalog/plotter/size.html
check this link out it sould give u your solution. Please get the size etc correct of the belt and iit should be really easy to find
Jul 05, 2009 | HP Designjet 5500PS 42 Printer Open Box
1-800-474-6836
Best Of Luck.
Nov 19, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
HP Designjet 5000 Printer Logo
214 people viewed this question
Seeker5211
Seeker5211
