Question about Jetway M1531S 15" Flat Panel LCD Monitor
How to connect build-in monitor speakers? should i just connect regular audio cord to "audio out" of comp to "audio in" of monitor? (if so, -it dosn't work). Help please
  • kuzma1 Feb 18, 2009
    The monitor (Nfren 15.1 TFT) has a RCA connectors. When I connect cables I can hear some scrachy sounds in speakers, what I take as a "working sign". External speakers work fine, means that comp is OK.
  • 1,602 Answers
Does the jack on lcd monitor, is it a screw type one, open or take aprt the screen area look at the speaker wires and take aprt the wire to you speaker if each have 2 wires you will be able if you have 3 or more wire you be able to talk to a tv repair man and see if he will make that connection for you permitily hard wire the two systems.
Posted on Feb 18, 2009
What cords are needed to connect my emachines windows 7 desktop computer?
  1. CPU Power Cord
  2. Monitor Power Cord
  3. Monitor video cable
  4. Mouse w/cable (unless wireless)
  5. Keyboard with cable (unless wireless)
  6. Network cable with 8P8C connectors (unless wireless)
  7. Speaker audio cable (unless internal or no speakers)
  8. Speaker power cable (unless CPU powered or no speakers)
Oct 22, 2015 | eMachines Computers & Internet
My computer is a SyncMasterP2570HD i cant get any sound to come out but it is detecting sound how do i fix it
The Samsung SyncMaster P2570hd is a monitor with speakers; it isn't the computer itself. I'll assume that you are dealing with a computer connected to the monitor and not a set-top box. Make sure that Mute is not enabled on the computer. There should be an icon on the lower right hand side of a Windows desktop. If the mute is enabled, it will have a red circle with a diagonal line through it. Left click on the icon to remove the mute (change the volume or click on the mute icon). Test the monitor's speakers by connecting it to another device with known good audio output.
Next how are you connecting the monitor to the computer (VGA, DVI or HDMI)? If you are using VGA or DVI (including DVI to HDMI), you need to connect an audio patch cable (3.5 mm) between the speaker (green port on the back of a sound card) or headphone jack of the computer and the audio input jack of the monitor. The audio input jack is between the DVI and VGA ports. You can test the output of the speaker jack on the computer with regular computer speakers. Plug in the power cord (or USB cable) for powered speakers. If the free-standing speakers work, check the volume setting on the monitor with the +/- buttons to the right of the menu button. Do not press menu first, though. If that doesn't solve the problem, continue using the separate speakers. (Unless the monitor is still under warranty, it usually isn't worth taking apart a monitor to replace the speakers. You may be able find replacement parts online.)
If you are using an HDMI cable, check the output audio setting to see if the HDMI audio is available. For Windows, click on Start > Control Panel > Hardware and Sound (Windows 7). Then click on Manage Audio Devices under Sound. In the Playback tab, check what available audio devices you have. Make the HDMI the default device by right-clicking on it and selecting Make this the default device. (Other versions of Windows will a slightly different route to this panel.) You may need to restart the computer to get the audio signal on the HDMI cable after setting this. Note: not all video cards/computers support HDMI audio. If you don't see HDMI listed in the Playback devices, connect an audio patch cable as with a VGA or DVI cable, described above. Use stand-alone speakers if the monitor's speakers are bad.
I hope this helps.
(I have had the speakers fail in monitors; <$30 separate speakers are an adequate replacement for those built into a flat panel monitor.)
Jun 26, 2012 | Audio Players & Recorders
I need to connect my old speakers to my new Samsung monitor. No instructions in manual. thanks, barb
You don't connect speakers to the monitor, you connect it to the tower of the computer. If I'm not understanding your question right then please be more specific. If your monitor has speakers, you connect the audio cord to the tower then to the monitor or vise versa.
Jul 29, 2011 | Samsung Syncmaster 940BW LCD Monitor
Monitor works perfectly, but after a recent crash of my comp. Ive lost all sound ..The comp doesnt seem to recognize the build in speakers..
The computer does not have to recognize the powered speakers that are built-in the monitor, the computer feeds the analog audio signal the powered speakers inside the montior, there is no driver needed either, but you do need the PC sound card driver for you to get sound through any powered speakers (either the desk top powered speakers or the one inside the montior).
Since your computer had crashed, the driver for the sound card may be have to be reloaded.
You can verify if the monitor speakers are working or not by feeding it with an MP3 player or sound output from CD player.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 14, 2011 | BenQ FP72E 17" LCD Monitor
Hooked up New Hp comp (tower only) to slightly new HP2007 monitor but there is no sound.Could you give me an idea of what I missed?
Make sure the audio cable supplied with the monitor is connected correctly. Make sure it is connected to the green (speaker out) jack at the back of tower and the same green (audio in) jack on the monitor. Also make sure the volume on both your PC and monitor is turned up and not muted
Dec 03, 2010 | HP W2007 LCD Monitor
No sound and video
Video issue:-
Assuming the system power comes up, does the monitor power come on? Most monitors have a status LED on the front bezel that should show green, orange, or blinking if the monitor is powered on. You can hear CRT monitors power on with a gentle sound, though I can't describe it beyond saying it's the sound of a CRT tube warming up. Make sure the monitor is plugged into a good outlet by testing the outlet with a lamp or any other device that will prove beyond a doubt that the outlet is good. Make sure that the power cord is either permanently attached at the monitor end or that it is seated fully in the socket, since partial cord insertion is the most common failure for monitors with detachable cords.
LCD displays don't make any sound when you turn them on, but they don't have a simple power cord, either. Older LCD monitors are usually powered by an external transformer, which in turn is powered from a regular AC outlet. If the LCD display doesn't show any signs of life, make sure that the cords into and out of the transformer are fully seated. Some transformers are equipped with a status LED to show when they are operating. The power connection to the LCD display is often awkward to inspect, recessed into the back of the display. The important thing is to make sure it is started correctly, then seated all the way.
Sound issue:-
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 06, 2010 | Computers & Internet
Connect a monitor to a yahama HTR 5660 receiver
"trying to connect multiple devices to a yamaha receiver if I am using an S video to connect the tv (monitor) to the receiver do I plug it into the monitor OUT s video or would it be Input not output?" Input on the Monitor from Video Out on the Yamaha.
"if I am only using the monitor for video and not sound do I still need to plug in the audio cords or do i leave them out " - Presumably the monitor doesn't have speakers or audio connections, so it's a non-issue. Your video sources should have audio routed to the receiver. If the monitor has speakers I would also send 2-channel analog audio to it from, say, the cable/satellite box, so you could hear the weather or other lo-fi video without turning on the Yamaha.
Mar 30, 2010 | Yamaha HTR-5660 Receiver
No inlet on my computer for my X223W LCD Monitors audio cord.
Is the monitor supplied with inbuilt speakers..? Most monitors no longer have inbuilt speakers and this is why there is no place to connect the audio cable. You will have to purchase a set of external speakers and connect these to the audio output of your system.
Dec 27, 2009 | Acer 22" X223w LCD Monitor
Monitor doesnt come on--just installed ecs a780GM mobo
Recheck all the hardware connections.
If it fine check the your CPU with another monitor. If it not works then fault with the CPU or software.
Hope this helps.
Feb 07, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Speaker trouble
There has to be separate cord for the speakers. Look for an Audio port on the back of the monitor. It looks like a small hole and should be marked "Audio". Connect this to the Audio out on the PC using a cable with two Audio jacks at both ends.
Dec 31, 2008 | Acer AL1914 19" LCD Monitor
Jetway M1531S 15" Flat Panel LCD Monitor Logo
100 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
