Question about Dive Rite Brass Pressure Gauge - Gauges - Gauges - Analog - Diving Ge
My diving gauge is stuck at 50 Bar even when I disconnect it from the air tank. When I reconnect it to the air tank the gauge stays at 50 bar yet I know I have 230 bar in the tank. Any ideas why?
  • 4 Answers
Need new gauge,
Posted on Feb 19, 2009
Why is my fuel gauge stuck on full even though there is only 50% of petrol in the petrol tank
Hi,it must be that the gauge or sender unit are faulty,check sender unit first.
Apr 09, 2016 | Cars & Trucks
How do I take apart a dewalt d5141 compr3ssor?
This number is for the D20114 its the safety valve that can not be set to a max basic pressure .
its strange but its not adjustable it can be defect i have one time the same the experience there is not a adjustable Pressure Switch on this model , the moast compressors have a 8 to12 bar adjustable.pressure switch.
Very important This safety valve gives an electronic brake between the pump and to a end of top about 10 bar . if its not switching off then a drain valve opened . and blows all the air out. (but only over 10 bar ) the max pressure on the tank , the moast tools are working on a pressure from 6 to 8 bar.
Checking Safety Valve
WARNING: Risk of bursting. If the safety valve does not work
properly, over-pressurization may occur, causing air tank rupture or
an explosion.
Before starting compressor, pull the ring on the safety valve to
make sure that the safety valve operates freely. If the valve is
stuck or does not operate smoothly, it must be replaced with the
same type of valve.
Draining Air Tank (Fig. 1)
WARNING: Risk of unsafe operation. Risk from noise. Air tanks
contain high pressure air. Keep face and other body parts away from
outlet of drain. Use safety glasses when draining as debris can be
kicked up into face. Use ANSI S12.6 (S3.19) ear protection as air flow
noise is loud when draining.
NOTE: All compressed air systems generate condensate that
accumulates in any drain point (e.g., tanks, filter, aftercoolers,
dryers). This condensate contains lubricating oil and/or substances
which may be regulated and must be disposed of in accordance with
local, state, and federal laws and regulations.
1. Ensure On/Off switch (A) is in the OFF position.
2. Move compressor into an inclined position so drain valve (H) is
at the lowest point (this will assist in removing moisture, dirt, etc.
from air tanks)
3. Place a suitable container under the drain valve to catch
discharge.
4. Grasp black lever on drain valve.
5. Slowly rotate lever to gradually bleed air from air tank.
6. When air tank pressure gauge reads 10 PSI (275.1 kPa), rotate
valve to the fully open position.
7. Close drain valve when finished
Apr 19, 2015 | Dewalt Air Tools & Compressors
Hooked up battery and the gauges do not work and can not start from handle bar start button but i can jumper the solinod to turn over what can i do to fix
Security code locked. if u dont know code you can reset by locating single wire with blue connector in front wiring bundle. disconnect then hold mode button down wait about 3 sec and enter new code then reconnect
Aug 15, 2011 | Yamaha 12V Air Pump
How to replace a sway bar end links to a 94 intrepid
REMOVAL & INSTALLATION
The rear suspension on LH platform vehicles is a fully independent suspension. A stabilizer bar (also called a sway bar) is mounted in rubber isolator bushings and connects the rear struts through links. Note that the fuel tank must be removed to remove the stabilizer bar.
CAUTION OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury.
  1. Disconnect the negative battery cable. Relieve the fuel system pressure.
  2. Raise and safely support the vehicle.
  3. Remove both rear wheels.
  1. Position a transmission jack under the fuel tank just forward of the crossmember to help support the fuel tank when crossmember is removed.
  2. Remove the four crossmember to frame rail attaching bolts. Remove the fuel tank.
  3. Remove the stabilizer bar to link assembly attaching nuts and remove the bar and isolator bushings as an assembly from the vehicle. Inspect the isolator bushings for damage or excessive wear and replace, if necessary.
To install:
  1. Inspect for broken or distorted retainers and bushings. If bushing replacement is required, replacement bushings can be installed by locating the split in the bushing, prying open and removing the defective bushing from around the stabilizer bar.
  2. Install the stabilizer bar and isolator bushings back into the vehicle as an assembly making sure bar is centered in vehicle so it doesn't contact other suspension components.
  3. Install stabilizer bar attaching link onto stabilizer bar. Install new link to bar attaching nuts and tighten to 70 ft. lbs. (95 Nm).
Replace the sway bar bracket bolt with new after loosening or removing them. Only use original equipment bolts as replacements.
  1. Install the fuel tank back onto the vehicle.
  2. Position the crossmember on frame rails and install four mounting bolts. Tighten attaching bolts to 70 ft. lbs. (95 Nm).
  3. Remove transmission jack from under the fuel tank.
  4. Install the rear wheels and lug nuts. Tighten the lug nuts, in a star pattern sequence, to 95-100 ft. lbs. (129-135 Nm).
  5. Lower the vehicle. Reconnect the negative battery cable.
  6. Pressurize the fuel system and check for leaks.
  7. Check and reset the rear wheel toe to specifications as required.
Jul 03, 2010 | 1994 Dodge Intrepid
Pressure gauge problem with Suunto Cobra 2
Salva,
The error in pressure is actually a "feature" of Suunto computers. Suunto is probably one of the most conservative brands out there, and many experienced divers tend to stay away from them for that very reason.
The manual actually calls out this "feature" on page 27.
The remaining air time calculation includes a 35 bar/500 psi safety reserve. This means
that when the instrument shows the air time to be zero, there is still about 35 bar/500 psi
of pressure left in your cylinder, depending on your air consumption rate.
http://media.suunto.com/media/suunto/manuals/en_US/cobra2_usersguide_en_v3_m56577569830698583.pdf
Regards,
Darlene
Jul 30, 2009 | Suunto Cobra Integrated Computer
Fuel gauge doesnt work
The fuel gauge in the fuel tank is simply a float connected to a bar connected to the sensor. Take a look at that and see if that float is stuck in one place causing a false reading.
Jan 11, 2009 | 1989 Chevrolet K1500
Why do scuba diving pressure gauges reach 5000 psi if a tank may only be filled to a max of around 3200?
Scuba tanks can be filled well past 3200psi. When they do a hydrostatic test it is well beyond any pressure that any dive shop will fill a tank to. The highest I've seen the pressure get in my tank is 4000 and that is when the filler at the dive shop forgot about it.
Dec 01, 2008 | Aeris Max Depth Analog 2 Gauge Console
How and why scuba gauges give a diver critical information while scuba diving?
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
Veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
Apr 06, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Dive Rite Brass Pressure Gauge  - Gauges - Gauges - Analog - Diving Ge Logo
169 people viewed this question
Top Dive Rite Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Dive Rite Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
