Question about Dishwashers
Top arm does not turn. leaves white stuff all over dishes.
    Novelist:
  • 117 Answers
Without having much information to go on, I would venture to guess there is a problem with the water supply. If the initial water fill level is low, the force of the water coming out of the spray arms is minimal and would never be forceful enough to dissolve the detergent used. When starting a a new cycle and it runs for a few minutes...filling then stopping, open the door and take a good look at the level of the water. If below the heating element, add about 1-2 gallons of water and close the door. Does the sound of the water seem to be more forceful? If so, remove your water supply line going to the dishwsher and look inside the valve itself. See if the screen is blocked. If it is, using a small screwdriver, scrape the screen and then blow it out. Reattach and see if the unit fills with more water this time. If I can help further, I am here....
Waiting to hear from you,
Eric Campion
Posted on Feb 18, 2009
Hello, Dishwasher is not cleaning well, it leaves a white film coating especially on top rack items. thanks
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins.
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Feb 13, 2011 | Dishwashers
It is leaving soap on the dishes. It is loaded properly and upon checking it while running, the arms aren't spraying water.
Hi
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Daniel
Feb 09, 2011 | Dishwashers
Our Asko dishwasher no longer cleans the top shelf of dishes properly. Fine white and black grit is left on the dishes after every wash, and if there is any food residue on the dishes it does not come off....
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Check also that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Feb 04, 2011 | Asko 24 in. D3350 Dishwasher
Dishes come out with white soapy residue and glasses in top rack are very cloudy. I don't think the center spray arm is turning.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Oct 05, 2010 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher leaving debri and food partical on dishes. the top arm seams to be not moving but water is getting threw.
top arms are normally free-wheeling, depending on water pressure from beneath to operate and distribute the rinse water. Is it possible you have dishes or utensils being placed in the top rack which would prohibit the arm from turning?
Nov 27, 2009 | Frigidaire Dishwashers
Dishwasher leaving white sticky residue on dishes
maybe machine is not filling with correct amount of water try adding an extra omunt of water say 2 litres and see if the machine sounds like it is washing properly
open the door when operating and observe wah arm positions as these turn aroun as it washes
also check that the wash arms are not blocked
Nov 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Dishes all cloudy and spotty. Maytag Intellisense plus 1996 dishwasher. I have real hard water that leave white calcium build up. I can remove and clean all of the lower spray arms and filter. How do I...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Mar 11, 2009 | Danby 22 in. DDW399 Free-standing...
Maytag Quiet Series 300/Dishwasher leaving gritty stuff on dishes
My model is simillar Cheri's. Every couple years I have to remove the plastic spray bars. They are held on by a simple torque screw. Once removed you will see debris plugging many of the holes. I have found this on all 4 of my spray bars. This debris prevents the right amount of water in the wash and rinse cycles. The upper spray bars seem to be the worse. This explains the trouble most folks have with glasses in the upper rack. Also check the docking station. You will fiind it along the back wall of your unit. The plastic tubes on the backside of each rack will slide into a hole in the docking station. After a few years the rubber seal in the docking station will be worn away. Once this happens, it prevents the correct water pressure to the upper rack. The replacement part snaps into place and cost about $25.
Jan 19, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Soap build up on dishwasher. Dries white and stays on dishes.
the spray arms is eather bad or the wash motor ,,,,, it isn't spraying water onto the dishes with any force.
Larry
Nov 25, 2008 | Dishwashers
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
