Canon PIXMA MX700 All-In-One InkJet Printer
Problem for Canon PIXMA MX700 All-In-One InkJet Printer
Canon PIXMA MX700 printhead immediately coated with ink, smudges
By lemaymd on Feb 18, 2009
I just purchased a reconditioned Canon PIXMA MX700, and it leaves concentrated cyan and/or black (hard to tell) smudges on all print outs, as shown on the left here: http://support-ph.canon-asia.com/contents/PH/EN/8200225400.html. Enabling "prevent paper abrasion" mode lifts the print head slightly and eliminates the problem, but slows down the printing. I took out the printhead and saw that it was completely coated in black-ish ink, so I wiped it down carefully (without touching the actual nozzles) with q-tips. It printed the next page perfectly, no smudges. The second page I printed after that had the smudges again! I took the printhead out again, and it was coated with ink even worse than before. :-( Anybody know what gives? The Canon techs had previously suggested a deep cleaning, but I didn't do that because it takes so much ink and the nozzle check pattern was perfect. Thanks!
Solution #1
posted on Sep 11, 2009
Not Rated)
JimDe
Rank: Master
Rating: 100%, 2 votes
It's likely that the foam pads that the print head rests on when the printer is not in use are saturated with ink. They're to the right as you look into the printer: a rectangular one for black ink and a square one for the colored ink. If you power the printer off and back on, with the cover open, you'll see where the printhead goes to rest.
The pads aren't easy to get at, but you can blot them with a paper towel. Gummy, half-dried ink dissolves in rubbing alcohol, and you can soak a paper towel or a cotton ball with alcohol and wipe down the area. I've had good luck soaking the pads with alcohol, then blotting them dry with a rag.
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MX700 All-In-One
Questions and Unsolved Problems for Canon PIXMA MX700 All-In-One
Do you recommend Canon PIXMA MX700 All-In-One InkJet Printer?
Answer
Answer
my scanner will only scan from the flat bed. I want to scan from the document feeder.
Answer
setting up PIXMA 860 WITH NEW MacBook Pro,it has the new snow leopard. I keep getting printer off... (More)
Answer
pixma mx700 wil not feed paper..started to feed skewed(to the right) now does not feed at all
Answer
Can't print from MAC OS X 10.5.8 to Canon MX700 network printer. Get error message pop-up box... (More)
Answer
my fax machine recieves faxes but does not send out
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
