Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore elite keeps flashing red on smart wash button. It won't do anything else.
  • Nikki Nicholson May 11, 2010
    What is the model? Could you be seeing the clean light flashing? Did it start cycle at all?
  • 15,935 Answers
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
The start button keeps blinking, WONT LET ME DO ANYTHING
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
Kenmore elite dishwasher smart wash flashes
This sounds like a door switch that is faulty on your main door so the system gets a signal saying its not closed properly and there for signals fault
Dec 20, 2013 | Dishwashers
Kenmore elite dishwasher has an error code f4e1
I had the F4E1 code on my Kenmore Elite 665x. This means a water leak. I eventually pulled the machine from the cabinet and noticed some water beneath the machine and the water pump hose loose. I reattached the pump hose using a new hose clamp and zip tied the pump in place to keep it from happening again. Afterwards I had to reset the machine by pushing the smart wash pots and pan then normal wash in sequential order 3 times then shut the door. The machine then does a diagnostic test. After the test I pushed the cancel button and it was ready to go.
Hope this helps someone else!
Nov 21, 2012 | Dishwashers
Kenmore Elite: Model 66576962K601.
I had exact same issue. I've called Sears Maintenance. They had to change 2 pieces in UI: Timer KUDS02SRB10 and CONSOLE Assy. Cost 360$ pieces  130$ Job Charge 60$ taxes.
Now It works perfectly, but I bought 1100$ 3 years ago... Really expensive to keep it running.
Nov 29, 2009 | Kenmore Dishwashers
Four hour delay light flashing
I have a kenmore elite dishwasher and the 6hour delay light is flashing and no other buttons work when I push them.. whats wrong?
Apr 11, 2009 | Kenmore Dishwashers
Kenmore Elite HE3 washer lights light but wash won't start
Sometimes I just have to unplug the machine, wait a few seconds and plug it back in and it works. I guess it resets itself or something.
Feb 26, 2009 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Feb 22, 2009 | Kenmore Dishwashers
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
504 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
