Question about Kenmore 63032 Electric Dryer
Kenmore model c1108021080 will not start. it just hums
The dryer used to start if you held the start button down long enough however now it cuts out prior to starting
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
catriver
  • 878 Answers
SOURCE: Kenmore Dryer Model No. 11062982100
Hi Missy K, this is a even heat dryer, sounds like you are going to need the even heat board. This is not hard to install, it's under the consol on the left side. Your part number is 3976627, if you go to repairclinic.com and enter the part number it will give you a picture of it and the price. This is a classic syptom of the even heat board failure. Catriver.
Posted on Jan 10, 2008
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 958 Answers
SOURCE: Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Series 90 dryer will
You have a broken belt.
Posted on Mar 10, 2009
98 series. Why doesn't it run?
Kenmore Whirlpool Dryer Won't Start - Easy Fix - YouTube
? 3:52
https://www.youtube.com/watch?v=MhVUEhngZMg
Jul 21, 2012 - Uploaded by Bill Newberry
This video will show you what you need to check if you press thestart button on your Kenmore or Whirlpool Dryer and it does notstart up. ... the button won't start it, and putting those wires together doesn't start the dryer, what ...
What to Test When Whirlpool or Kenmore Dryer Won't Start ...
? 7:17
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jan 24, 2013 - Uploaded by canyonman1963
What to Test When Whirlpool or Kenmore Dryer Won't Start orRun ... discusses all of the common causes of an electric dryernot starting or running. Category. People & Blogs. License. Standard YouTube License. Show more
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
This video is the 2nd of several that will show you how to diagnose and repair a Whirlpool or Kenmore electric dryer that will not start or run.
Jan 13, 2016 | Kenmore Dryers
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Kenmore dryer model 86950100, when I push the start button it just hums and will not start.First time it did it I waited 1/2 hour then it ran fine for couple days and now it started again, just hums. I...
the humming is coming from the motor,if you can spin the drum by hand and it moves freely you need to replace the motor,if it's hard to move you need to take the dryer apart to see why it's hanging up,the overload resets on the motor that's why after a while you'll hear the hum again,if you hold the button to long you'll pop the overload
Mar 26, 2010 | Kenmore Dryers
Dryer won't run when push button it will run for awhile then stop. push button again it will not run humming sound replace starter switch did not help
you have a bad motor,that's what is humming,it's heating up and cutting out,when it cools down it will start again but soon that will stop also
Jan 23, 2010 | Kenmore Dryers
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
I have a Kenmore dryer model no. 1109282610. When
the motor is humming,could be something stuck in blower wheel,might of had lint filter out and ran dryer and something went down into blower wheel,the belt could be locked up or the motor is bad,take the belt off of motor and see if motor spins
Nov 02, 2009 | Kenmore Dryers
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
Dryer won't run except when start button is held
you need a new start button and switch
Jan 12, 2009 | Kenmore Dryers
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Kenmore 63032 Electric Dryer Logo
77 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
