Question about Sanyo PLC-XU50A Multimedia Projector
PROJECTOR WON'T PROJECT IMAGE - Sanyo PLC-XU50A Multimedia Projector
  • galman0909
    galman0909 May 11, 2010
    any specifics?
  • neOen May 11, 2010
    Require more info: What type of input? dvd? computer? what type of connection? VGA? Component?
  • 82 Answers
Check the lamp, if it is bad, there are many places to get the lamp, http://www.partstore.com/
is a good place to start
Posted on Jul 26, 2009
Panasonic interactive whiteboard won't project computer
If you'd like to email me at bruce.brassington@n-vest.co.uk I'll be able to help you in more detail. There's a fundamental error to the question here. That is the board in itself will not show the image - your boards is effectively a large flat mouse. A pointing device infact. The peice of equipment that "shows" your PC image is actually the projector. There could be several reasons why your projector isn't showing the image.
1 - is there either a VGA or HDMI cable connected from your laptop/PC to the projector (Sometimes via a wall plate).
2 If 1 is true and the projector is turned on does it show any sort of image? Now there are two thongs you can do from here. a) If you have a laptop check to see if your Video settings are set to clone across to a secondary monitor on most laptops you should hold down Function key and F8 this will toggle through three options Onboard screen remote screen and then both. there could be some lag between the two so hold down fucntio at the same time press F8 then wait a few seconds then go again.
Finally on you projector remote there may be an auto search buttion which will hunt for your PC image by checking each of the Projector inputs in turn. Generally speaking however you should select "Computer 1" or sometimes named as RGB 1
Hope that helps email me if your still having problems.
Aug 21, 2012 | Panasonic Panaboard Ub-T880 Interactive...
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
How to write on wall with some image or photo?
If I understand correctly you want to project an image on the wall.
If this is correct, then open following links to Texas Art Supply:
http://www.texasart.com/tools/light-boxes-and-projectors/projectors/artograph-tracer-projector.html
http://www.texasart.com/tools/light-boxes-and-projectors/projectors/artograph-prism-image-projectors.html
http://www.texasart.com/search/index.cfm?searchstring=projector&store=ALL&x=22&y=13
How it works.
Place image on table.
Put projector over top of image.
Turn on projector, and image is projected to wall or piece of paper hanging on wall.
Trace image or paint directly on the surface.
Feb 12, 2011 | Cycling
Dell 4100MP Image Not Centered Thru Lens
No to your question. The lens is fixed it cannot shift horizontally only although there are projectors that can do this. I am sure you have the front foot retracted? I have had to do the same as you are doing or find a lower table.
Jun 02, 2010 | Dell 4100MP Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Mounting the Projector from the Ceiling
Projectors, in general want to project the bottom of the image 1 foot above the lens at a typical range. When mounted upside down, they project the top of the image 1 foot below the center of the lens. If you don't want to turn the projector over, you'll have to change the angle and probably go to the extreme on the keystone correction.
Aug 05, 2009 | Dell 1200MP DLP Projector
Projected image is not the same as computer monitor
as long as nobody has physically changed the lens poition, you can go into the menu on the projector and do a factory reset. this should default the settings back to where the installer put them.
Feb 05, 2008 | Mitsubishi ES100U Multimedia Projector
Projection is so dim
Hi there
Sounds to me like it is time for a new lamp.
Jan 23, 2008 | HP Digital Projector Vp6120 Multimedia...
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
Sanyo PLC-XU50A Multimedia Projector Logo
268 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
