Question about Acer Aspire™ T180 PC Desktop
The drawer in the tower for discs will not open I can hear the motor trying to open it but it seems stuck in
  • Acer Master
  • 5,568 Answers
Unfortunately, the clutches are very unreliable in optical drives.
Check for a very small hole above or below the drawer. If you find one, take a standard paper clip, straighten it, push it into the hole. It may take several tries to find the manual release but there will be one if there is a hole at all. It may also take a firm push to release the drawer.
I am well-versed in repair of many things but have not had enough interest to see if the drawer clutch can be improved as I have two that are reluctant at best to open and seem to be only willing after several pushes of the eject button.   The things are cheap enough today that it probably isn't worth the effort to see if they can be restored to reliable operation. If someone else has doen this; give us some feedback as to whether this is worthwhile or not.
Posted on Feb 18, 2009
Magnavox ZV457MG9 A DVD drawer won't open
one of the faults with the home dvd player it seems we have to open them to remove the stuck dvd .and more often than not we end up braekingthe danged thing anyway
Mar 15, 2015 | Magnavox Televison & Video
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
The DVD drawer will not open unless a disc is in the drive. When the drawer would not open I took the cover off the player. The DRC8295N is a VCR-DVD/R RW player recorder. The DVD drive will record on...
The problem isn't with the motor being too weak, but the belt which the motor drives. I had the EXACT problem just as you described. What I did was I took off the belt and cleaned it with rubbing alcohol because apparently the belt picked up some of the grease from the gears and wouldn't rotate when the motor spinned. This belt actually pulls down the mechanism, on which the CD sits, from the magnet. So, just clean the belt and you should be good to go. If the belt is very loose, you might need to replace it.
Feb 14, 2011 | RCA DRC8295N DVD Recorder/VCR
I have a DVD that is stuck in my TIVO. The screen
Take the DVD player aparts,take out DVD disc out of the drawer,check the open/close drawer button again.Same result indication on the screen say is open infact it close.The motor the help open and the dvd drawer it dead.Need the motor replaced.
Jun 26, 2010 | Humax T800 TiVo 80-Hours Video Recorder
My cd disc is stuck inside my tower the drawer goes in and out but the disc is still inside the tower
look at the hole near the eject button of the optical disc. insert a pin to force eject it..
goodluck
Apr 10, 2010 | Dell Computers & Internet
Disc drawer won't open and sometimes doesn't power off
The disc drawer is broken, there are motors that open the drawer (what you hear when turned on and off) and it must of got damaged by a cd or some other way. If you want to open it, pry it open with your fingers or screwdriver. I had to take the 5 cd holders out to see the problem and there was a cd that jammed everything. But you might not have that, take a look. And the "bye bye" thing is normal but not if it wont go off at all.
Oct 06, 2009 | RCA RTD207 System
It doesnt recognise cds
There are a few possible causes. 1. Lens on laser pickups dirty. 2. The belt that closes the drawer also lifts the CD assembly to allow disc to spin. If the belt is loose, drawer may close but not be able to lift CD. Listen to mechanism after drawer closes. Do you hear the disc spinning up? or Do you hear a motor trying and then shutting off? You can also remove the case top and visually check these. 3. The spindle height may have slipped. 4. The focus and tracking may have changed with age. 5. The pickup may be bad. And finally the carriage may be stuck and not moving the Pickup(Laser Assembly) to its start position.
Jul 17, 2009 | JVC MX-D401T Shelf System
Disc drawer will not open
Try to hear a sound of of a running motor inside the unit. If you can hear it, the there's a broken or misplaced rubber belt. The belt drives the drawer open.
Nov 25, 2008 | JVC XL-F254BK 5-Disc CD Changer
Acer Aspire™ T180 PC Desktop Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
